跳转到主内容
加入维修社区 - 创建账户
Fujifilm Instax Mini 8 Flash Unit Replacement
你所需要的
  1. Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: 步骤 1 中的图像 1,2 Fujifilm Instax Mini 8 Flash Unit Replacement, Flash Unit: 步骤 1 中的图像 2,2
    • You start off with the camera.
    询问修复机器人
    添加评论
  2. Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 2 中的图像 1,2 Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 2 中的图像 2,2
    • Open up the back and remove the film cartridge.
    询问修复机器人
    添加评论
  3. Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 3 中的图像 1,2 Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 3 中的图像 2,2
    • Remove the two Phillips #00 screws from the bottom of the camera.
    • Remove the two screws on the side of the camera.
    • Additionally, there are two screws in the battery compartment which also need to be removed.
    添加评论
  4. Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 4 中的图像 1,3 Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 4 中的图像 2,3 Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 4 中的图像 3,3
    • Once all screws are removed, gently pry open the front casing with your hands or a prying tool.
    • There will be a spring that attaches the front casing and the main circuit board, so take care as to not break the spring.
    询问修复机器人
    添加评论
  5. Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 5 中的图像 1,1
    • You should now be able to see the flash unit. Take care to not touch the large black capacitor on the top. It will still have a charge and will hurt.
    询问修复机器人
    添加评论
  6. Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 6 中的图像 1,2 Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 6 中的图像 2,2
    • Unscrew the two screws attaching the flash to the main circuit board. The flash unit will detach away from the motherboard, now leaving just the connecting wires to remove next.
    询问修复机器人
    添加评论
  7. Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 7 中的图像 1,3 Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 7 中的图像 2,3 Fujifilm Instax Mini 8 Flash Unit Replacement: 步骤 7 中的图像 3,3
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Bo W
于10/02/12注册
1,037 声望
创作了5篇指南
团队
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 的会员
USFT-MEIER-F15S4G1
4 名成员
创作了26篇指南
10指南评论
Where can I purchase the flash unit?
Casey Sanders - 回复 分享
Hi, did you ever find out where to replace the flash light unit?
Rachel Street - 回复 分享
Why is all the camera lights flashing red and doesn't work?
medgabby - 回复 分享
Will the camera work without any flash, or are the connections required for the whole thing to function ?
Hyaku Gen - 回复 分享
Where can I find the flash unit to purchase??
Maria - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 31
过去 30 天: 153
总计 37,463
