跳转到主内容
加入维修社区 - 创建账户
Front Panel Assembly Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Front Panel Assembly Removal, Disconnect the home button: 步骤 1 中的图像 1,2 Front Panel Assembly Removal, Disconnect the home button: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
  2. Front Panel Assembly Removal: 步骤 2 中的图像 1,2 Front Panel Assembly Removal: 步骤 2 中的图像 2,2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
  3. Front Panel Assembly Removal: 步骤 3 中的图像 1,2 Front Panel Assembly Removal: 步骤 3 中的图像 2,2
    • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
  4. Front Panel Assembly Removal, Disconnect the display cables: 步骤 4 中的图像 1,3 Front Panel Assembly Removal, Disconnect the display cables: 步骤 4 中的图像 2,3 Front Panel Assembly Removal, Disconnect the display cables: 步骤 4 中的图像 3,3
    • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  5. Front Panel Assembly Removal, Remove the vibration isolator: 步骤 5 中的图像 1,3 Front Panel Assembly Removal, Remove the vibration isolator: 步骤 5 中的图像 2,3 Front Panel Assembly Removal, Remove the vibration isolator: 步骤 5 中的图像 3,3
    • Use the flat end of a spudger to pry up the vibration isolator near the bottom-right corner of the device.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the vibration isolator.
  6. Front Panel Assembly Removal: 步骤 6 中的图像 1,2 Front Panel Assembly Removal: 步骤 6 中的图像 2,2
    • The home button cable is secured with some light adhesive.
    • Use a pair of tweezers to peel the home button cable away from the frame.
  7. Front Panel Assembly Removal, Remove the front panel assembly: 步骤 7 中的图像 1,3 Front Panel Assembly Removal, Remove the front panel assembly: 步骤 7 中的图像 2,3 Front Panel Assembly Removal, Remove the front panel assembly: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Polyimide Tape
    $9.99
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
结论
Alex Diaz-Kokaisl
于01/16/22注册
216,837 声望
创作了1,047篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,918篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 74
