跳转到主内容
加入维修社区 - 创建账户
Front Inner Tube Replacement
  1. Front Inner Tube Replacement, Front Inner Tube: 步骤 1 中的图像 1,2 Front Inner Tube Replacement, Front Inner Tube: 步骤 1 中的图像 2,2
    • First, remove the front wheel from the frame by unscrewing the adjustable screw
    询问修复机器人
    添加评论
  2. Front Inner Tube Replacement: 步骤 2 中的图像 1,3 Front Inner Tube Replacement: 步骤 2 中的图像 2,3 Front Inner Tube Replacement: 步骤 2 中的图像 3,3
    • Next, wedge tire tool below the bike wheel, right above the rim.
    • Once firmly in place, push the tire tool down towards the ground in order to create spacing between the tire and the rim.
    • Following this, grab the 2nd tire tool and place it into the gap you have created.
    • Slide the 2nd tool around the entire circumference of the tire, while holding the first in place, in order to dislodge the tire from the rim.
    询问修复机器人
    添加评论
  3. Front Inner Tube Replacement: 步骤 3 中的图像 1,2 Front Inner Tube Replacement: 步骤 3 中的图像 2,2
    • After removing the bike tire, locate the bike valve used to pump air into the tire.
    • Gently remove the inner tube starting with the area around the valve.
    • Make a note of where the hole for the valve is located on the bike rim, because that is where the next step begins.
    询问修复机器人
    添加评论
  4. Front Inner Tube Replacement: 步骤 4 中的图像 1,1
    • Pump a small amount of air into the new bike tube so that it is easier to work with.
    • Next, locate the hole in the bike rim and feed the valve through and into position.
    • Next, wrap the rest of the tubing over the rim comfortably, while making sure that no folds or creases form on the tube.
    询问修复机器人
    添加评论
  5. Front Inner Tube Replacement: 步骤 5 中的图像 1,2 Front Inner Tube Replacement: 步骤 5 中的图像 2,2
    • Finish by placing the bike tire back on the the frame, while making sure that no fold or creases form in the tube.
    • Lastly, pump air into the tire and remount onto bike frame.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions.
取消:我没有完成这个指南。
3等其他人完成本指南。
Theo Tzeng
于07/22/13注册
59 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 32
过去 30 天: 174
总计 3,226
