简介
Touchpad installation prereq guide
你所需要的
Make sure the small tabs around the alignment tool are folded down around the touchpad. Use your fingers to fold them down if they're not.
Use your Framework Screwdriver to install the seven 2.1 mm‑long T5 Torx screws to secure the touchpad.
Slide the keyboard ZIF cable into its connector, up to the printed line on the cable.
Use your finger to flip down and gently press the locking tab in place.
Use your fingers to peel and remove the alignment tool from the touchpad.
