跳转到主内容
Framework Laptop 12 SSD Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Framework Laptop 12 SSD Removal, Power down your laptop: 步骤 1 中的图像 1,3 Framework Laptop 12 SSD Removal, Power down your laptop: 步骤 1 中的图像 2,3 Framework Laptop 12 SSD Removal, Power down your laptop: 步骤 1 中的图像 3,3
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 SSD Removal, Set your laptop down: 步骤 2 中的图像 1,1
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 SSD Removal, Loosen the bottom screws: 步骤 3 中的图像 1,2 Framework Laptop 12 SSD Removal, Loosen the bottom screws: 步骤 3 中的图像 2,2
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
  4. Framework Laptop 12 SSD Removal, Flip your laptop over: 步骤 4 中的图像 1,1
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 SSD Removal, Open your laptop: 步骤 5 中的图像 1,2 Framework Laptop 12 SSD Removal, Open your laptop: 步骤 5 中的图像 2,2
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 SSD Removal, Remove the Input Cover: 步骤 6 中的图像 1,3 Framework Laptop 12 SSD Removal, Remove the Input Cover: 步骤 6 中的图像 2,3 Framework Laptop 12 SSD Removal, Remove the Input Cover: 步骤 6 中的图像 3,3
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 SSD Removal, Unlatch the SSD: 步骤 7 中的图像 1,2 Framework Laptop 12 SSD Removal, Unlatch the SSD: 步骤 7 中的图像 2,2
    • Use your finger to press down on the black SSD latch to unlatch the SSD.
    • The SSD will pop up to an angle when it's unlatched.
  8. Framework Laptop 12 SSD Removal, Remove the SSD: 步骤 8 中的图像 1,3 Framework Laptop 12 SSD Removal, Remove the SSD: 步骤 8 中的图像 2,3 Framework Laptop 12 SSD Removal, Remove the SSD: 步骤 8 中的图像 3,3
    • Grab the SSD by its edges and pull it out of its socket.
    • Remove the SSD.
终点
Arthur Shi
于01/03/18注册
313,608 声望
创作了729篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 35
