跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 12 Memory Module Replacement
你所需要的
  1. Framework Laptop 12 Memory Module Replacement, Power down your laptop: 步骤 1 中的图像 1,3 Framework Laptop 12 Memory Module Replacement, Power down your laptop: 步骤 1 中的图像 2,3 Framework Laptop 12 Memory Module Replacement, Power down your laptop: 步骤 1 中的图像 3,3
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
    询问修复机器人
    添加评论
  2. Framework Laptop 12 Memory Module Replacement, Set your laptop down: 步骤 2 中的图像 1,1
    • Set your Framework Laptop face-down on a clean work surface.
    询问修复机器人
    添加评论
  3. Framework Laptop 12 Memory Module Replacement, Loosen the bottom screws: 步骤 3 中的图像 1,2 Framework Laptop 12 Memory Module Replacement, Loosen the bottom screws: 步骤 3 中的图像 2,2
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    询问修复机器人
    添加评论
  4. Framework Laptop 12 Memory Module Replacement, Flip your laptop over: 步骤 4 中的图像 1,1
    • Flip your laptop over so it's face-up on your work surface.
    询问修复机器人
    添加评论
  5. Framework Laptop 12 Memory Module Replacement, Open your laptop: 步骤 5 中的图像 1,2 Framework Laptop 12 Memory Module Replacement, Open your laptop: 步骤 5 中的图像 2,2
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
    询问修复机器人
    添加评论
  6. Framework Laptop 12 Memory Module Replacement, Remove the Input Cover: 步骤 6 中的图像 1,3 Framework Laptop 12 Memory Module Replacement, Remove the Input Cover: 步骤 6 中的图像 2,3 Framework Laptop 12 Memory Module Replacement, Remove the Input Cover: 步骤 6 中的图像 3,3
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
    询问修复机器人
    添加评论
  7. Framework Laptop 12 Memory Module Replacement, Open the memory flap: 步骤 7 中的图像 1,2 Framework Laptop 12 Memory Module Replacement, Open the memory flap: 步骤 7 中的图像 2,2
    • Use your fingers to flip open the memory flap.
    询问修复机器人
    添加评论
  8. Framework Laptop 12 Memory Module Replacement, Remove the memory module: 步骤 8 中的图像 1,2 Framework Laptop 12 Memory Module Replacement, Remove the memory module: 步骤 8 中的图像 2,2
    • Use your fingers to spread the clips on both sides of the memory module apart to unclip the memory.
    • The memory module will pop up to an angle when it's unclipped.
    询问修复机器人
    添加评论
  9. Framework Laptop 12 Memory Module Replacement: 步骤 9 中的图像 1,2 Framework Laptop 12 Memory Module Replacement: 步骤 9 中的图像 2,2
    • Use your fingers to grab the memory module by its edges.
    • Slide the memory module out of its socket and remove it.
    询问修复机器人
    添加评论
  10. Framework Laptop 12 Memory Module Replacement, Disassembly complete: 步骤 10 中的图像 1,1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
    询问修复机器人
    添加评论
  11. Framework Laptop 12 Memory Module Replacement, Install the memory module: 步骤 11 中的图像 1,3 Framework Laptop 12 Memory Module Replacement, Install the memory module: 步骤 11 中的图像 2,3 Framework Laptop 12 Memory Module Replacement, Install the memory module: 步骤 11 中的图像 3,3
    • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Orient the module with the label facing down and align the gold contacts with the socket.
    • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • Press the edges of the memory module down until the side clips lock it in place.
    添加评论
  12. Framework Laptop 12 Memory Module Replacement: 步骤 12 中的图像 1,2 Framework Laptop 12 Memory Module Replacement: 步骤 12 中的图像 2,2
    • Flip the memory flap back over the memory module.
    询问修复机器人
    添加评论
  13. Framework Laptop 12 Memory Module Replacement, Install the Input Cover: 步骤 13 中的图像 1,3 Framework Laptop 12 Memory Module Replacement, Install the Input Cover: 步骤 13 中的图像 2,3 Framework Laptop 12 Memory Module Replacement, Install the Input Cover: 步骤 13 中的图像 3,3
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
    询问修复机器人
    添加评论
  14. Framework Laptop 12 Memory Module Replacement, Close and flip your laptop: 步骤 14 中的图像 1,2 Framework Laptop 12 Memory Module Replacement, Close and flip your laptop: 步骤 14 中的图像 2,2
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
    询问修复机器人
    添加评论
  15. Framework Laptop 12 Memory Module Replacement, Tighten the bottom screws: 步骤 15 中的图像 1,2 Framework Laptop 12 Memory Module Replacement, Tighten the bottom screws: 步骤 15 中的图像 2,2
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
    询问修复机器人
    添加评论
结论
You finished fixing your Framework Laptop!
After installing new memory, the laptop will take longer to start up for the first time, and the screen will turn on slower. This is normal—the system is performing memory training.
If you need help, contact Framework support.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Arthur Shi
于01/03/18注册
336,813 声望
创作了849篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了17,836篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 50
总计 753
