简介
Mainboard installation prereq guide
你所需要的
Carefully lay the Mainboard in the laptop.
Use the two alignment pins to help align the Mainboard to the laptop.
Be careful not to trap the webcam or display cables under the Mainboard as you set it in place.
Use your fingers to carefully move the Wi-Fi card over the Mainboard.
Hold the Wi-Fi card down with your finger.
Position the black antenna cable connector over the left Wi-Fi card's coaxial socket.
Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
Repeat the procedure with the white antenna cable.
Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Wi-Fi card.
