跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 12 Fan Replacement
你所需要的
  1. Framework Laptop 12 Fan Replacement, Power down your laptop: 步骤 1 中的图像 1,3 Framework Laptop 12 Fan Replacement, Power down your laptop: 步骤 1 中的图像 2,3 Framework Laptop 12 Fan Replacement, Power down your laptop: 步骤 1 中的图像 3,3
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Fan Replacement, Set your laptop down: 步骤 2 中的图像 1,1
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Fan Replacement, Loosen the bottom screws: 步骤 3 中的图像 1,2 Framework Laptop 12 Fan Replacement, Loosen the bottom screws: 步骤 3 中的图像 2,2
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
  4. Framework Laptop 12 Fan Replacement, Flip your laptop over: 步骤 4 中的图像 1,1
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 Fan Replacement, Open your laptop: 步骤 5 中的图像 1,2 Framework Laptop 12 Fan Replacement, Open your laptop: 步骤 5 中的图像 2,2
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 Fan Replacement, Remove the Input Cover: 步骤 6 中的图像 1,3 Framework Laptop 12 Fan Replacement, Remove the Input Cover: 步骤 6 中的图像 2,3 Framework Laptop 12 Fan Replacement, Remove the Input Cover: 步骤 6 中的图像 3,3
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 Fan Replacement, Disconnect the fan connector: 步骤 7 中的图像 1,3 Framework Laptop 12 Fan Replacement, Disconnect the fan connector: 步骤 7 中的图像 2,3 Framework Laptop 12 Fan Replacement, Disconnect the fan connector: 步骤 7 中的图像 3,3
    • Use the flat end of your Framework Screwdriver to gently push on one of the fan connector's protruding edges, then the other, to loosen the connector out of its socket.
  8. Framework Laptop 12 Fan Replacement: 步骤 8 中的图像 1,2 Framework Laptop 12 Fan Replacement: 步骤 8 中的图像 2,2
    • Use your fingers and your Framework Screwdriver to slide the fan connector out of its socket.
  9. Framework Laptop 12 Fan Replacement, Loosen the fan screws: 步骤 9 中的图像 1,1
    • Use your Framework Screwdriver to loosen the two captive T5 Torx screws securing the fan.
  10. Framework Laptop 12 Fan Replacement, Remove the fan: 步骤 10 中的图像 1,2 Framework Laptop 12 Fan Replacement, Remove the fan: 步骤 10 中的图像 2,2
    • Lift and remove the fan.
  11. Framework Laptop 12 Fan Replacement, Clean the fan: 步骤 11 中的图像 1,2 Framework Laptop 12 Fan Replacement, Clean the fan: 步骤 11 中的图像 2,2
    • If your fan's dirty, this is a great opportunity to clean it! A clean fan will help your laptop stay cooler.
    • Use a soft bristled brush or a clean toothbrush to gently scrub the fan blades and exhaust fins.
    • Use a dust blower to blow away the dust from the fan.
  12. Framework Laptop 12 Fan Replacement, Disassembly complete: 步骤 12 中的图像 1,1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  13. Framework Laptop 12 Fan Replacement, Install the fan: 步骤 13 中的图像 1,1
    • Lay the fan in the laptop.
  14. Framework Laptop 12 Fan Replacement, Tighten the fan screws: 步骤 14 中的图像 1,1
    • Use your Framework Screwdriver to tighten the two captive T5 Torx screws to secure the fan.
  15. Framework Laptop 12 Fan Replacement: 步骤 15 中的图像 1,2 Framework Laptop 12 Fan Replacement: 步骤 15 中的图像 2,2
    • Use your fingers to gently push the fan connector back into its socket.
    • Don't push too hard, or you may break the socket. If you're having trouble, wiggle the connector slightly to help it slide into the socket.
  16. Framework Laptop 12 Fan Replacement, Install the Input Cover: 步骤 16 中的图像 1,3 Framework Laptop 12 Fan Replacement, Install the Input Cover: 步骤 16 中的图像 2,3 Framework Laptop 12 Fan Replacement, Install the Input Cover: 步骤 16 中的图像 3,3
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
  17. Framework Laptop 12 Fan Replacement, Close and flip your laptop: 步骤 17 中的图像 1,2 Framework Laptop 12 Fan Replacement, Close and flip your laptop: 步骤 17 中的图像 2,2
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  18. Framework Laptop 12 Fan Replacement, Tighten the bottom screws: 步骤 18 中的图像 1,2 Framework Laptop 12 Fan Replacement, Tighten the bottom screws: 步骤 18 中的图像 2,2
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
结论
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
于01/03/18注册
324,013 声望
创作了802篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了16,343篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 30
总计 591
