简介
Follow this guide to remove and replace the Display Cover in your Framework Laptop 12.
The Display Cover is the plastic bezel strip below the screen. You can easily replace a broken one or swap out a different colored one.
你所需要的
Open the laptop lid so that both the screen and the base lie flat on your work surface.
Use the flat end of your Framework Screwdriver to pry up the right edge of the Display Cover.
结论
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
