跳转到主内容
加入维修社区 - 创建账户
Framework Laptop 12 Audio Board Replacement
你所需要的
  1. Framework Laptop 12 Audio Board Replacement, Power down your laptop: 步骤 1 中的图像 1,3 Framework Laptop 12 Audio Board Replacement, Power down your laptop: 步骤 1 中的图像 2,3 Framework Laptop 12 Audio Board Replacement, Power down your laptop: 步骤 1 中的图像 3,3
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 Audio Board Replacement, Set your laptop down: 步骤 2 中的图像 1,1
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 Audio Board Replacement, Loosen the bottom screws: 步骤 3 中的图像 1,2 Framework Laptop 12 Audio Board Replacement, Loosen the bottom screws: 步骤 3 中的图像 2,2
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
  4. Framework Laptop 12 Audio Board Replacement, Flip your laptop over: 步骤 4 中的图像 1,1
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 Audio Board Replacement, Open your laptop: 步骤 5 中的图像 1,2 Framework Laptop 12 Audio Board Replacement, Open your laptop: 步骤 5 中的图像 2,2
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 Audio Board Replacement, Remove the Input Cover: 步骤 6 中的图像 1,3 Framework Laptop 12 Audio Board Replacement, Remove the Input Cover: 步骤 6 中的图像 2,3 Framework Laptop 12 Audio Board Replacement, Remove the Input Cover: 步骤 6 中的图像 3,3
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 Audio Board Replacement, Loosen the Audio Board screw: 步骤 7 中的图像 1,1
    • Use your Framework Screwdriver to loosen the captive T5 Torx screw securing the Audio Board along the left edge of the laptop.
  8. Framework Laptop 12 Audio Board Replacement, Remove the Audio Board: 步骤 8 中的图像 1,3 Framework Laptop 12 Audio Board Replacement, Remove the Audio Board: 步骤 8 中的图像 2,3 Framework Laptop 12 Audio Board Replacement, Remove the Audio Board: 步骤 8 中的图像 3,3
    • Use your fingers to lift the right edge of the Audio Board and pull it out of its recess.
    • Remove the Audio Board.
  9. Framework Laptop 12 Audio Board Replacement, Disassembly complete: 步骤 9 中的图像 1,1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  10. Framework Laptop 12 Audio Board Replacement, Install the Audio Board: 步骤 10 中的图像 1,3 Framework Laptop 12 Audio Board Replacement, Install the Audio Board: 步骤 10 中的图像 2,3 Framework Laptop 12 Audio Board Replacement, Install the Audio Board: 步骤 10 中的图像 3,3
    • Insert the Audio Board into the laptop at an angle to help align the headphone jack.
    • Use the two plastic alignment pins on the laptop to help with final alignment.
  11. Framework Laptop 12 Audio Board Replacement: 步骤 11 中的图像 1,1
    • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Audio Board.
    • Tighten the screw until it's snug. Don't over-tighten it, or you may strip the screw.
  12. Framework Laptop 12 Audio Board Replacement, Install the Input Cover: 步骤 12 中的图像 1,3 Framework Laptop 12 Audio Board Replacement, Install the Input Cover: 步骤 12 中的图像 2,3 Framework Laptop 12 Audio Board Replacement, Install the Input Cover: 步骤 12 中的图像 3,3
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
  13. Framework Laptop 12 Audio Board Replacement, Close and flip your laptop: 步骤 13 中的图像 1,2 Framework Laptop 12 Audio Board Replacement, Close and flip your laptop: 步骤 13 中的图像 2,2
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  14. Framework Laptop 12 Audio Board Replacement, Tighten the bottom screws: 步骤 14 中的图像 1,2 Framework Laptop 12 Audio Board Replacement, Tighten the bottom screws: 步骤 14 中的图像 2,2
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
结论
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
于01/03/18注册
317,924 声望
创作了736篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了16,163篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 297
