简介
Follow this guide to remove and replace the Front Panel in your Framework Desktop.
If you want to install or remove Tiles, follow this guide instead.
你所需要的
Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
Press the Front Panel flat to the chassis and let it align to the magnets.
If you need help, contact Framework support.
另外一个人完成了本指南。
