跳转到主内容
加入维修社区 - 创建账户
Framework Desktop Fastener Kit
你所需要的
  1. Framework Desktop Fastener Kit, Fastener information: 步骤 1 中的图像 1,2 Framework Desktop Fastener Kit, Fastener information: 步骤 1 中的图像 2,2
    • The Fastener Kit contains the following:
    • Four screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick"
    • Two large screws labeled "M6 ring screws"
    • Four screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick"
    • Eight screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick"
    • Four long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick"
    • Your Framework Desktop comes with a spare screw of each size attached to the bottom of the top plate. You can use the Fastener Kit to replenish any screws you used there.
    • Not included in the Fastener Kit is a silver 4.5 mm‑long T5 Torx screw that secures the SSD covers, I/O shield, and USB‑C brackets.
    询问修复机器人
    添加评论
  2. Framework Desktop Fastener Kit, Top Panel screws: 步骤 2 中的图像 1,3 Framework Desktop Fastener Kit, Top Panel screws: 步骤 2 中的图像 2,3 Framework Desktop Fastener Kit, Top Panel screws: 步骤 2 中的图像 3,3
    • The two screws labeled "M6 ring screws" secure the Top Panel.
    询问修复机器人
    添加评论
  3. Framework Desktop Fastener Kit, Fan screws: 步骤 3 中的图像 1,2 Framework Desktop Fastener Kit, Fan screws: 步骤 3 中的图像 2,2
    • The long screws labeled "26.5 mm fastener with a 7.0 mm diameter 2.0 mm thick" secure the Fan.
    询问修复机器人
    添加评论
  4. Framework Desktop Fastener Kit, Mainboard screws: 步骤 4 中的图像 1,2 Framework Desktop Fastener Kit, Mainboard screws: 步骤 4 中的图像 2,2
    • The screws labeled "6.0 mm fastener with a 7.3 mm diameter 2.3 mm thick" secure the Mainboard.
    询问修复机器人
    添加评论
  5. Framework Desktop Fastener Kit, Power supply screws: 步骤 5 中的图像 1,2 Framework Desktop Fastener Kit, Power supply screws: 步骤 5 中的图像 2,2
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 2.0 mm thick" secure the power supply.
    询问修复机器人
    添加评论
  6. Framework Desktop Fastener Kit, Top plate screws: 步骤 6 中的图像 1,3 Framework Desktop Fastener Kit, Top plate screws: 步骤 6 中的图像 2,3 Framework Desktop Fastener Kit, Top plate screws: 步骤 6 中的图像 3,3
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the top plate.
    询问修复机器人
    添加评论
  7. Framework Desktop Fastener Kit, Rear plate screws: 步骤 7 中的图像 1,3 Framework Desktop Fastener Kit, Rear plate screws: 步骤 7 中的图像 2,3 Framework Desktop Fastener Kit, Rear plate screws: 步骤 7 中的图像 3,3
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the rear plate.
    询问修复机器人
    添加评论
  8. Framework Desktop Fastener Kit, Side power supply screw: 步骤 8 中的图像 1,2 Framework Desktop Fastener Kit, Side power supply screw: 步骤 8 中的图像 2,2
    • The screws labeled "4.0 mm fastener with a 5.5 mm diameter 0.9 mm thick" secure the side of the power supply.
    询问修复机器人
    添加评论
  9. Framework Desktop Fastener Kit, Power duct screws: 步骤 9 中的图像 1,3 Framework Desktop Fastener Kit, Power duct screws: 步骤 9 中的图像 2,3 Framework Desktop Fastener Kit, Power duct screws: 步骤 9 中的图像 3,3
    询问修复机器人
    添加评论
结论
If you need help, contact Framework support.
取消:我没有完成这个指南。
Alex Diaz-Kokaisl
于01/16/22注册
240,628 声望
创作了1,180篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 29
总计 256
