跳转到主内容
加入维修社区 - 创建账户
Framework Desktop CPU Fan Replacement
你所需要的
    1. Framework Desktop CPU Fan Replacement, Power down your Desktop: 步骤 1 中的图像 1,3 Framework Desktop CPU Fan Replacement, Power down your Desktop: 步骤 1 中的图像 2,3 Framework Desktop CPU Fan Replacement, Power down your Desktop: 步骤 1 中的图像 3,3
      • Before you begin repairs, shut down your desktop from the operating system and unplug it.
      • Wait one minute before continuing to allow your Desktop to fully power down.
      • Make sure your Framework Desktop Screwdriver has the Phillips #2 bit (labeled as PH2) facing outwards. If it's not, pull the bit out and flip it.
      询问修复机器人
      添加评论
    1. Framework Desktop CPU Fan Replacement, Remove the Handle: 步骤 2 中的图像 1,3 Framework Desktop CPU Fan Replacement, Remove the Handle: 步骤 2 中的图像 2,3 Framework Desktop CPU Fan Replacement, Remove the Handle: 步骤 2 中的图像 3,3
      • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
      • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
      • Remove the Handle.
      询问修复机器人
      添加评论
    2. Framework Desktop CPU Fan Replacement, Remove the Top Panel screws: 步骤 3 中的图像 1,3 Framework Desktop CPU Fan Replacement, Remove the Top Panel screws: 步骤 3 中的图像 2,3 Framework Desktop CPU Fan Replacement, Remove the Top Panel screws: 步骤 3 中的图像 3,3
      • Use your finger to lift up the two D-rings on the Top Panel screws.
      询问修复机器人
      添加评论
    3. Framework Desktop CPU Fan Replacement: 步骤 4 中的图像 1,3 Framework Desktop CPU Fan Replacement: 步骤 4 中的图像 2,3 Framework Desktop CPU Fan Replacement: 步骤 4 中的图像 3,3
      • Use your fingers to twist the screw counter-clockwise and loosen it.
      • Remove the Top Panel screw.
      询问修复机器人
      添加评论
    4. Framework Desktop CPU Fan Replacement: 步骤 5 中的图像 1,3 Framework Desktop CPU Fan Replacement: 步骤 5 中的图像 2,3 Framework Desktop CPU Fan Replacement: 步骤 5 中的图像 3,3
      • Repeat the same procedure for the other Top Panel screw.
      询问修复机器人
      添加评论
    5. Framework Desktop CPU Fan Replacement, Remove the Top Panel: 步骤 6 中的图像 1,3 Framework Desktop CPU Fan Replacement, Remove the Top Panel: 步骤 6 中的图像 2,3 Framework Desktop CPU Fan Replacement, Remove the Top Panel: 步骤 6 中的图像 3,3
      • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
      • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
      • Lift the Top Panel off the chassis and remove it.
      询问修复机器人
      添加评论
    1. Framework Desktop CPU Fan Replacement, Remove the Left Panel: 步骤 7 中的图像 1,3 Framework Desktop CPU Fan Replacement, Remove the Left Panel: 步骤 7 中的图像 2,3 Framework Desktop CPU Fan Replacement, Remove the Left Panel: 步骤 7 中的图像 3,3
      • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
      • Remove the Left Panel.
      询问修复机器人
      添加评论
    1. Framework Desktop CPU Fan Replacement, Lay down the Desktop: 步骤 8 中的图像 1,2 Framework Desktop CPU Fan Replacement, Lay down the Desktop: 步骤 8 中的图像 2,2
      • Lay down the Desktop on its side so the fan is facing upward.
      询问修复机器人
      添加评论
    2. Framework Desktop CPU Fan Replacement, Disconnect the fan: 步骤 9 中的图像 1,2 Framework Desktop CPU Fan Replacement, Disconnect the fan: 步骤 9 中的图像 2,2
      • Use your fingers to lift the APU fan cable connector off its four‑pronged socket on the Mainboard.
      询问修复机器人
      添加评论
    3. Framework Desktop CPU Fan Replacement: 步骤 10 中的图像 1,2 Framework Desktop CPU Fan Replacement: 步骤 10 中的图像 2,2
      • If you aren't using an RGB fan, then skip this step.
      • Use your fingers to lift the fan RGB cable connector off its three‑pronged socket on the Mainboard.
      询问修复机器人
      添加评论
    4. Framework Desktop CPU Fan Replacement, Remove the CPU fan screws: 步骤 11 中的图像 1,2 Framework Desktop CPU Fan Replacement, Remove the CPU fan screws: 步骤 11 中的图像 2,2
      • Use your Framework Desktop Screwdriver to remove the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
      询问修复机器人
      添加评论
    5. Framework Desktop CPU Fan Replacement, Remove the fan duct: 步骤 12 中的图像 1,2 Framework Desktop CPU Fan Replacement, Remove the fan duct: 步骤 12 中的图像 2,2
      • Lift the fan duct off the fan and remove it.
      询问修复机器人
      添加评论
    6. Framework Desktop CPU Fan Replacement, Remove the fan: 步骤 13 中的图像 1,3 Framework Desktop CPU Fan Replacement, Remove the fan: 步骤 13 中的图像 2,3 Framework Desktop CPU Fan Replacement, Remove the fan: 步骤 13 中的图像 3,3
      • Lift the fan out of the chassis, making sure the cables thread through the side of the heatsink.
      询问修复机器人
      添加评论
    1. Framework Desktop CPU Fan Replacement, Disassembly complete: 步骤 14 中的图像 1,1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
      询问修复机器人
      添加评论
    1. Framework Desktop CPU Fan Replacement, Insert the CPU fan: 步骤 15 中的图像 1,2 Framework Desktop CPU Fan Replacement, Insert the CPU fan: 步骤 15 中的图像 2,2
      • Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
      • If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
      • If you're using a different fan, orient it such that the fan is blowing towards the heatsink, not away.
      • Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
      询问修复机器人
      添加评论
    2. Framework Desktop CPU Fan Replacement: 步骤 16 中的图像 1,3 Framework Desktop CPU Fan Replacement: 步骤 16 中的图像 2,3 Framework Desktop CPU Fan Replacement: 步骤 16 中的图像 3,3
      • If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
      • If you're installing an RGB fan, make sure the "male" end of the RGB cable is covered and set aside in the corner of the chassis.
      询问修复机器人
      添加评论
    3. Framework Desktop CPU Fan Replacement, Insert the fan duct: 步骤 17 中的图像 1,2 Framework Desktop CPU Fan Replacement, Insert the fan duct: 步骤 17 中的图像 2,2
      • Lay the fan duct on top of the fan with the lip facing upward.
      • Align the screw holes on the fan duct with the ones on the fan.
      询问修复机器人
      添加评论
    4. Framework Desktop CPU Fan Replacement, Install the fan screws: 步骤 18 中的图像 1,2 Framework Desktop CPU Fan Replacement, Install the fan screws: 步骤 18 中的图像 2,2
      • Remove the fan screws from their packaging and make sure there are four screws total.
      询问修复机器人
      添加评论
    5. Framework Desktop CPU Fan Replacement: 步骤 19 中的图像 1,2 Framework Desktop CPU Fan Replacement: 步骤 19 中的图像 2,2
      • Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
      询问修复机器人
      添加评论
    6. Framework Desktop CPU Fan Replacement, Connect the fan: 步骤 20 中的图像 1,2 Framework Desktop CPU Fan Replacement, Connect the fan: 步骤 20 中的图像 2,2
      • Orient the main fan cable so its two vertical lines are facing you.
      • Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
      询问修复机器人
      添加评论
    7. Framework Desktop CPU Fan Replacement, Connect the RGB cable: 步骤 21 中的图像 1,3 Framework Desktop CPU Fan Replacement, Connect the RGB cable: 步骤 21 中的图像 2,3 Framework Desktop CPU Fan Replacement, Connect the RGB cable: 步骤 21 中的图像 3,3
      • Orient the RGB cable so the arrow is on the right side of the connector.
      • Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
      询问修复机器人
      添加评论
    1. Framework Desktop CPU Fan Replacement, Install the Left Panel: 步骤 22 中的图像 1,3 Framework Desktop CPU Fan Replacement, Install the Left Panel: 步骤 22 中的图像 2,3 Framework Desktop CPU Fan Replacement, Install the Left Panel: 步骤 22 中的图像 3,3
      • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
      • There should be a small gap between the bottom of the Left Panel and the silver base.
      • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
      询问修复机器人
      添加评论
    1. Framework Desktop CPU Fan Replacement, Install the Top Panel: 步骤 23 中的图像 1,3 Framework Desktop CPU Fan Replacement, Install the Top Panel: 步骤 23 中的图像 2,3 Framework Desktop CPU Fan Replacement, Install the Top Panel: 步骤 23 中的图像 3,3
      • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
      • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
      • There should be a small gap between the Top Panel and the front of the Desktop.
      • Lay the Top Panel flat on the chassis to align the remaining clips.
      询问修复机器人
      添加评论
    2. Framework Desktop CPU Fan Replacement: 步骤 24 中的图像 1,2 Framework Desktop CPU Fan Replacement: 步骤 24 中的图像 2,2
      • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
      询问修复机器人
      添加评论
    3. Framework Desktop CPU Fan Replacement, Install the Handle: 步骤 25 中的图像 1,2 Framework Desktop CPU Fan Replacement, Install the Handle: 步骤 25 中的图像 2,2
      • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
      • Place the Handle over the Top Panel screw holes.
      • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
      询问修复机器人
      添加评论
    4. Framework Desktop CPU Fan Replacement, Install the top panel screws: 步骤 26 中的图像 1,3 Framework Desktop CPU Fan Replacement, Install the top panel screws: 步骤 26 中的图像 2,3 Framework Desktop CPU Fan Replacement, Install the top panel screws: 步骤 26 中的图像 3,3
      • Insert the top panel screw into its hole and twist clockwise until it feels snug.
      询问修复机器人
      添加评论
    5. Framework Desktop CPU Fan Replacement: 步骤 27 中的图像 1,3 Framework Desktop CPU Fan Replacement: 步骤 27 中的图像 2,3 Framework Desktop CPU Fan Replacement: 步骤 27 中的图像 3,3
      • Repeat the same procedure for the other top panel screw.
      询问修复机器人
      添加评论
    6. Framework Desktop CPU Fan Replacement: 步骤 28 中的图像 1,3 Framework Desktop CPU Fan Replacement: 步骤 28 中的图像 2,3 Framework Desktop CPU Fan Replacement: 步骤 28 中的图像 3,3
      • Use your finger to close the two D-rings on the top panel screws.
      询问修复机器人
      添加评论
结论
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
取消:我没有完成这个指南。
Alex Diaz-Kokaisl
于01/16/22注册
246,543 声望
创作了1,203篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 33
过去 30 天: 159
总计 2,341
