跳转到主内容
加入维修社区 - 创建账户
Fosera Scandle 200 Solar Panel Replacement
你所需要的
    1. Fosera Scandle 200 Solar Panel Replacement, Solar Panel: 步骤 1 中的图像 1,1
      • Open the case by pulling the back tab toward you in a downward motion.
      询问修复机器人
      添加评论
    2. Fosera Scandle 200 Solar Panel Replacement: 步骤 2 中的图像 1,1
      • Unscrew the two Phillips #2 5mm screws that hold the power cord in place.
      询问修复机器人
      添加评论
    3. Fosera Scandle 200 Solar Panel Replacement: 步骤 3 中的图像 1,1
      • Use the flat-end of the spudger to pry off the clamp which holds the cord down.
      询问修复机器人
      添加评论
    4. Fosera Scandle 200 Solar Panel Replacement: 步骤 4 中的图像 1,1
      • Use the soldering iron to melt down the solder on each terminal by holding the tip of the iron against the solder until it becomes liquefied.
      询问修复机器人
      添加评论
    5. Fosera Scandle 200 Solar Panel Replacement: 步骤 5 中的图像 1,1
      • Gently pull the leads free from the terminals. If they do not easily separate from the terminals, repeat Step 4.
      • Now any solar panel of appropriate Voltage rating can be used to charge the device by soldering the wire leads to the new panel. Try to find a panel with similar specifications to avoid overloading the battery.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Vincent C
于09/23/14注册
134 声望
撰写一个指南
团队
USF Tampa, Team 12-5, Blackwell Fall 2014 USF Tampa, Team 12-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S12G5
4 名成员
创作了28篇指南
3指南评论
In order to use solar energy efficiently, we need to learn how to store solar energy. Unfortunately, we can only store a small fraction of the sun's energy.
niks adonis - 回复 分享
More information here.
niks adonis - 回复 分享
Go to the link.
niks adonis - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 1,024
