简介
The most difficult part of this operation is finding the necessary screws that will have to be removed using a PH2 Phillips Head screw driver and spudger. In order to view the vacuum pump and/or inspect the inner workings of you appliance this bottom panel must be removed first.
你所需要的
Use the PH2 screwdriver to remove the three 14mm Phillips Head screws.
Use a plastic opening tool to remove the rubber toppers, covering four more 14mm Phillips Head screws, and remove those screws with the same screwdriver.
3等其他人完成本指南。
