跳转到主内容
加入维修社区 - 创建账户
Flydigi Apex 5 Battery Replacement
你所需要的
  1. Flydigi Apex 5 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Flydigi Apex 5 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Orient the controller so that its back is facing you.
    • Apply firm downward pressure to remove both the M3 and M4 back paddles.
    询问修复机器人
    添加评论
  2. Flydigi Apex 5 Battery Replacement: 步骤 2 中的图像 1,3 Flydigi Apex 5 Battery Replacement: 步骤 2 中的图像 2,3 Flydigi Apex 5 Battery Replacement: 步骤 2 中的图像 3,3
    • Turn the controller over so its front faces you.
    • Remove the D-pad by firmly pulling it away from the body of the controller.
    询问修复机器人
    添加评论
  3. Flydigi Apex 5 Battery Replacement: 步骤 3 中的图像 1,3 Flydigi Apex 5 Battery Replacement: 步骤 3 中的图像 2,3 Flydigi Apex 5 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the clear, magnetically-adhered faceplate of the controller by firmly pulling it away from the body of the controller starting from the edge of the faceplate.
    询问修复机器人
    添加评论
  4. Flydigi Apex 5 Battery Replacement: 步骤 4 中的图像 1,3 Flydigi Apex 5 Battery Replacement: 步骤 4 中的图像 2,3 Flydigi Apex 5 Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the small cover from the rear of the controller by pushing it upward.
    • Remove the two 5.8mm screws behind the battery cover using a Phillips #0 screwdriver.
    询问修复机器人
    添加评论
  5. Flydigi Apex 5 Battery Replacement: 步骤 5 中的图像 1,2 Flydigi Apex 5 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the six 10mm long screws from the front of the controller using a Torx T6 screwdriver.
    询问修复机器人
    添加评论
  6. Flydigi Apex 5 Battery Replacement: 步骤 6 中的图像 1,3 Flydigi Apex 5 Battery Replacement: 步骤 6 中的图像 2,3 Flydigi Apex 5 Battery Replacement: 步骤 6 中的图像 3,3
    • Insert the plastic opening tool between the top and bottom plastic controller molds, then pry until the two pieces separate.
    • Be careful not to fully separate the two pieces of the controller. There is a fragile ribbon cable connecting the two sides that must be carefully disconnected in the next step.
    询问修复机器人
    添加评论
  7. Flydigi Apex 5 Battery Replacement: 步骤 7 中的图像 1,3 Flydigi Apex 5 Battery Replacement: 步骤 7 中的图像 2,3 Flydigi Apex 5 Battery Replacement: 步骤 7 中的图像 3,3
    • Carefully remove the back paddle ribbon cable with the angled tweezers or spudger.
    询问修复机器人
    添加评论
  8. Flydigi Apex 5 Battery Replacement: 步骤 8 中的图像 1,3 Flydigi Apex 5 Battery Replacement: 步骤 8 中的图像 2,3 Flydigi Apex 5 Battery Replacement: 步骤 8 中的图像 3,3
    • Press a prong of each side of the angled tweezers under the lip of the power supply cable connector and pull the plastic connector out of its terminal.
    • Pull the power supply cable through the plastic cable guides.
    询问修复机器人
    添加评论
  9. Flydigi Apex 5 Battery Replacement: 步骤 9 中的图像 1,3 Flydigi Apex 5 Battery Replacement: 步骤 9 中的图像 2,3 Flydigi Apex 5 Battery Replacement: 步骤 9 中的图像 3,3
    • Optional: Drip isopropyl alcohol along the sides of the battery. Then rotate the controller to distribute the alcohol and dissolve the adhesive holding the battery to the mount
    • Pry up the battery with the plastic hook and pry tool.
    • Do not use sharp metal tools to pry the battery out. That action risks puncturing the battery.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 70
总计 193
