跳转到主内容
加入维修社区 - 创建账户
Fluke 77 Series III Dial Replacement
你所需要的
    1. Fluke 77 Series III Dial Replacement, Front Panel: 步骤 1 中的图像 1,1
      • Be sure any test leads are out and the multimeter is off before opening the device.
      • Turn the multimeter so it is display side down.
      • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
      询问修复机器人
      添加评论
    2. Fluke 77 Series III Dial Replacement: 步骤 2 中的图像 1,1
      • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
      询问修复机器人
      添加评论
    3. Fluke 77 Series III Dial Replacement: 步骤 3 中的图像 1,2 Fluke 77 Series III Dial Replacement: 步骤 3 中的图像 2,2
      • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
      • Pry the front panel from the back panel at the seam.
      • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
      询问修复机器人
      添加评论
    1. Fluke 77 Series III Dial Replacement, Dial: 步骤 4 中的图像 1,1
      • Hold front panel with both hands, with your thumbs on the dial axle. The dial axle is the metal rod that comes out from the middle of the white plastic rotating piece.
      • Firmly press down on the dial axle to separate the dial from the front panel.
      • If this is difficult to do with your hands, push the dial axle against something hard, like the edge of a table.
      询问修复机器人
      添加评论
    2. Fluke 77 Series III Dial Replacement: 步骤 5 中的图像 1,1
      • With the dial loosened, pull the white plastic rotating piece until it comes off the dial axle.
      询问修复机器人
      添加评论
    3. Fluke 77 Series III Dial Replacement: 步骤 6 中的图像 1,1
      • Finally, push again on the dial axle with your thumb while at the same time pulling the dial off the front panel with your other hand .
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 2-10, Amido Winter 2014 Cal Poly, Team 2-10, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G10
4 名成员
创作了39篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 48
总计 3,495
