跳转到主内容
加入维修社区 - 创建账户
Flip Video Lens Replacement
你所需要的
  1. Flip Video Lens Replacement, Outer Shell: 步骤 1 中的图像 1,2 Flip Video Lens Replacement, Outer Shell: 步骤 1 中的图像 2,2
    • Turn off the device and take the batteries out.
    • Remove metal sticker under the LCD screen with a spudger.
    • This may require a large force to pry off the glued sticker.
    询问修复机器人
    添加评论
  2. Flip Video Lens Replacement: 步骤 2 中的图像 1,1
    • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
    询问修复机器人
    添加评论
  3. Flip Video Lens Replacement: 步骤 3 中的图像 1,2 Flip Video Lens Replacement: 步骤 3 中的图像 2,2
    • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
    询问修复机器人
    添加评论
  4. Flip Video Lens Replacement: 步骤 4 中的图像 1,1
    • Open battery door. This can be done by gently depressing and sliding the battery down downward.
    询问修复机器人
    添加评论
  5. Flip Video Lens Replacement: 步骤 5 中的图像 1,1
    • Use the spudger to separate outer shells.
    • The spudger must be inserted between the shell halves to pry the edges apart.
    • Slowly work around the outside to separate the halves.
    询问修复机器人
    添加评论
  6. Flip Video Lens Replacement, Circuit Board: 步骤 6 中的图像 1,1
    • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
    询问修复机器人
    添加评论
  7. Flip Video Lens Replacement: 步骤 7 中的图像 1,1
    • Slowly lift the left side of the circuit board.
    • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
    询问修复机器人
    添加评论
  8. Flip Video Lens Replacement: 步骤 8 中的图像 1,1
    • Disconnect the USB port cable from the back side of the circuit board.
    询问修复机器人
    添加评论
  9. Flip Video Lens Replacement: 步骤 9 中的图像 1,1
    • Slide out the battery contacts.
    • Battery contacts
    • Slot where battery contacts were located
    询问修复机器人
    添加评论
  10. Flip Video Lens Replacement, LCD Screen: 步骤 10 中的图像 1,1
    • With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
    询问修复机器人
    添加评论
  11. Flip Video Lens Replacement: 步骤 11 中的图像 1,1
    • Flip over the circuit board and unlock the two black tabs on the ribbon connector by sliding them upwards.
    询问修复机器人
    添加评论
  12. Flip Video Lens Replacement: 步骤 12 中的图像 1,1
    • Gently pull out ribbon cable.
    • If the ribbon cable does not come out easily you may not have fully unlocked the ribbon cable connector in the previous step.
    • The LCD screen is now removed and can be replaced.
    询问修复机器人
    添加评论
  13. Flip Video Lens Replacement, Lens: 步骤 13 中的图像 1,2 Flip Video Lens Replacement, Lens: 步骤 13 中的图像 2,2
    • Flip over circuit board so the ribbon connector is facing up.
    • Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
    • The lens can now be removed and replaced.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Elizabeth
于04/15/10注册
100 声望
创作了6篇指南
团队
Cal Poly, Team 26-21, Regan Spring 2010 Cal Poly, Team 26-21, Regan Spring 2010 的会员
CPSU-REGAN-S10S26G21
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 26
总计 4,984
