跳转到主内容
加入维修社区 - 创建账户
Flashforge Nozzle Unclogging
你所需要的
视频概述
    1. Flashforge Nozzle Unclogging, Loosen the nozzle: 步骤 1 中的图像 1,1
      • First, turn the printer off by flipping the switch located in the back of the printer to the OFF position.
      询问修复机器人
      添加评论
    2. Flashforge Nozzle Unclogging, Unscrewing the extruder: 步骤 2 中的图像 1,1
      • Get the smallest Allen Key that is included with the package, then unscrew it until the head of the screw is sitting above the assembly
      询问修复机器人
      添加评论
    3. Flashforge Nozzle Unclogging, Taking out the nozzle: 步骤 3 中的图像 1,2 Flashforge Nozzle Unclogging, Taking out the nozzle: 步骤 3 中的图像 2,2
      • Press and hold the red latches that are on both sides, then you must gently pull the nozzle out while wiggling it a bit. The nozzle should come out.
      询问修复机器人
      添加评论
    4. Flashforge Nozzle Unclogging, Taking out the clog: 步骤 4 中的图像 1,1
      • With the nozzle out, cut or pull any filament sticking up from the top.
      询问修复机器人
      添加评论
    5. Flashforge Nozzle Unclogging, Putting the nozzle back in: 步骤 5 中的图像 1,1
      • After that, push the nozzle back in with the pins facing the back and the nozzle sign facing you. Push it in gently until it clicks.
      询问修复机器人
      添加评论
    6. Flashforge Nozzle Unclogging, Tightening the screw: 步骤 6 中的图像 1,1
      • With the same Allen Key, Screw the key in until it is flush with the assembly.
      询问修复机器人
      添加评论
    7. Flashforge Nozzle Unclogging, Turning the printer back on: 步骤 7 中的图像 1,1
      • With the switch located at the back, flip it to the On position. If the light shows up at the screen, Your printer is not done for and is in an OK position. If it does not post, you will have to take it to a repair shop.
      询问修复机器人
      添加评论
结论
This should make your 3d printer work, I hope your printer was fixed, have a good day/night!!
取消:我没有完成这个指南。
另外一个人完成了本指南。
Wyatt
于09/18/25注册
175 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 61
总计 538
