跳转到主内容
加入维修社区 - 创建账户
Fitbit Surge Touchscreen Sensor Replacement
你所需要的
    1. Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: 步骤 1 中的图像 1,2 Fitbit Surge Touchscreen Sensor Replacement, Touchscreen Sensor: 步骤 1 中的图像 2,2
      • Unscrew all four black 3 mm screws on the underside of the watch using a T5 screwdriver.
      询问修复机器人
      添加评论
    2. Fitbit Surge Touchscreen Sensor Replacement: 步骤 2 中的图像 1,3 Fitbit Surge Touchscreen Sensor Replacement: 步骤 2 中的图像 2,3 Fitbit Surge Touchscreen Sensor Replacement: 步骤 2 中的图像 3,3
      • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
      • Note: Part of the band is hard plastic.
      • Caution: Once the band is cut it cannot be reattached.
      询问修复机器人
      添加评论
    3. Fitbit Surge Touchscreen Sensor Replacement: 步骤 3 中的图像 1,2 Fitbit Surge Touchscreen Sensor Replacement: 步骤 3 中的图像 2,2
      • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
      询问修复机器人
      添加评论
    4. Fitbit Surge Touchscreen Sensor Replacement: 步骤 4 中的图像 1,1
      • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
      询问修复机器人
      添加评论
    5. Fitbit Surge Touchscreen Sensor Replacement: 步骤 5 中的图像 1,2 Fitbit Surge Touchscreen Sensor Replacement: 步骤 5 中的图像 2,2
      • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
      • Note: the buttons will also come off.
      询问修复机器人
      添加评论
    6. Fitbit Surge Touchscreen Sensor Replacement: 步骤 6 中的图像 1,1
      • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
      • Note: A spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
      询问修复机器人
      添加评论
    7. Fitbit Surge Touchscreen Sensor Replacement: 步骤 7 中的图像 1,1
      • Remove the touchscreen sensor using a spudger or your fingers.
      • Note: In this photo we removed the metal cover on the main PCB, but you do not need to remove it for this guide.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Keep in mind that the wristband will need to be cut for this repair and it cannot be reattached.
取消:我没有完成这个指南。
7等其他人完成本指南。
Angela Pitts
于10/11/16注册
1,190 声望
创作了4篇指南
团队
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G3
3 名成员
创作了8篇指南
5指南评论
Is there a company that will perform this fix for me?
Terry Brown - 回复 分享
Where can I get a replacement sensor?
Francisco Cortez - 回复 分享
Isn’t any step missing in that instruction ?
Removing sensor will solve the issue ? How about adding new one ?
Erazm Gondoresku - 回复 分享
Hi, I didnt get the point, what should I do after removing sensor? Should I clean it or something? If I need to place a new one, maybe someone knows where to get one?
viktoras - 回复 分享
Is anyway I can buy the bus
Ajay Kumar - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 33
总计 3,319
