跳转到主内容
加入维修社区 - 创建账户
Fitbit Ionic Battery Replacement
你所需要的
  1. Fitbit Ionic Battery Replacement, How to open the Fitbit Ionic: 步骤 1 中的图像 1,2 Fitbit Ionic Battery Replacement, How to open the Fitbit Ionic: 步骤 1 中的图像 2,2
    • Before starting, take your Fitbit Ionic off the charger and power it down.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  2. Fitbit Ionic Battery Replacement: 步骤 2 中的图像 1,1
    • Heat an iOpener and apply it on the display for at least two minutes to soften the adhesive underneath.
    • The adhesive of the Fitbit Ionic is very strong. You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
  3. Fitbit Ionic Battery Replacement: 步骤 3 中的图像 1,3 Fitbit Ionic Battery Replacement: 步骤 3 中的图像 2,3 Fitbit Ionic Battery Replacement: 步骤 3 中的图像 3,3
    • Insert a technician's razor with a flat blade into the small gap between the watch case and the display.
    • Cut through the adhesive on the upper side of the Fitbit Ionic.
  4. Fitbit Ionic Battery Replacement: 步骤 4 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 4 中的图像 2,2
    • Use a technician's razor with a flat blade to pry up the top edge of the display and create a small gap.
  5. Fitbit Ionic Battery Replacement: 步骤 5 中的图像 1,3 Fitbit Ionic Battery Replacement: 步骤 5 中的图像 2,3 Fitbit Ionic Battery Replacement: 步骤 5 中的图像 3,3
    • Insert two opening picks underneath the top left and the top right corner.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    • Remove the razor blade.
  6. Fitbit Ionic Battery Replacement: 步骤 6 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 6 中的图像 2,2
    • Insert a third opening pick underneath the top right corner and slide it along the right edge of the display.
    • Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
  7. Fitbit Ionic Battery Replacement: 步骤 7 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 7 中的图像 2,2
    • Insert a fourth opening pick underneath the top left corner and slide it along the left edge of the display.
    • Leave the opening pick in bottom left corner to prevent the adhesive from resealing.
    • Do not remove the display assembly all the way yet—it's still connected to the mainboard.
  8. Fitbit Ionic Battery Replacement: 步骤 8 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 8 中的图像 2,2
    • Carefully fold the display assembly in the direction of the bottom edge.
  9. Fitbit Ionic Battery Replacement, Display Assembly: 步骤 9 中的图像 1,2 Fitbit Ionic Battery Replacement, Display Assembly: 步骤 9 中的图像 2,2
    • Use the flat end of a spudger to loosen and pry up the mildly glued NFC antenna.
    • Carefully fold the NFC antenna in the direction of the upper edge of the watch.
  10. Fitbit Ionic Battery Replacement: 步骤 10 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 10 中的图像 2,2
    • Carefully fold the display assembly onto the upper side of the watch.
    • Take care not to pull or bend the cables too much—they are still connected to the mainboard.
  11. Fitbit Ionic Battery Replacement: 步骤 11 中的图像 1,1
    • Remove the Torx T2 screw (3.65 mm length) on the bottom left corner.
  12. Fitbit Ionic Battery Replacement: 步骤 12 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the metal shield covering the battery flex cable.
  13. Fitbit Ionic Battery Replacement: 步骤 13 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 13 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery flex cable.
  14. Fitbit Ionic Battery Replacement: 步骤 14 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 14 中的图像 2,2
    • Fold the display assembly back to its original position.
  15. Fitbit Ionic Battery Replacement: 步骤 15 中的图像 1,1
    • Remove the two Torx T2 screws (3.65 mm length) from the top edge of the watch.
  16. Fitbit Ionic Battery Replacement: 步骤 16 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 16 中的图像 2,2
    • Use a pair of tweezers to remove the metal cover.
  17. Fitbit Ionic Battery Replacement: 步骤 17 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 17 中的图像 2,2
    • Use a spudger to pry up and disconnect the NFC antenna.
    • Remove the NFC antenna.
  18. Fitbit Ionic Battery Replacement: 步骤 18 中的图像 1,3 Fitbit Ionic Battery Replacement: 步骤 18 中的图像 2,3 Fitbit Ionic Battery Replacement: 步骤 18 中的图像 3,3
    • Use a spudger to pry up and disconnect the two display cables from the motherboard.
  19. Fitbit Ionic Battery Replacement: 步骤 19 中的图像 1,1
    • Remove the display assembly.
    • If possible, turn on your Fitbit Ionic and test your repair before installing new adhesive and resealing.
  20. Fitbit Ionic Battery Replacement, Battery: 步骤 20 中的图像 1,1
    • Remove the Torx T2 screw (3.65 mm length).
  21. Fitbit Ionic Battery Replacement: 步骤 21 中的图像 1,2 Fitbit Ionic Battery Replacement: 步骤 21 中的图像 2,2
    • Use a spudger to pry up and disconnect the heart rate sensor from the motherboard.
  22. Fitbit Ionic Battery Replacement: 步骤 22 中的图像 1,3 Fitbit Ionic Battery Replacement: 步骤 22 中的图像 2,3 Fitbit Ionic Battery Replacement: 步骤 22 中的图像 3,3
    • Insert a spudger into the gap between the watchcase and the upper edge of the motherboard.
    • Use the spudger to pry up the motherboard.
    • Avoid damaging the battery and heart rate sensor cables during the motherboard removal procedure.
    • Remove the motherboard.
  23. Fitbit Ionic Battery Replacement: 步骤 23 中的图像 1,1
    • Remove the four Torx T2 screws (1.8 mm length).
  24. Fitbit Ionic Battery Replacement: 步骤 24 中的图像 1,3 Fitbit Ionic Battery Replacement: 步骤 24 中的图像 2,3 Fitbit Ionic Battery Replacement: 步骤 24 中的图像 3,3
    • Insert the flat end of a spudger between the watchcase and the battery on the top edge of your Fitbit Ionic.
    • Use the spudger to pry up the battery.
  25. Fitbit Ionic Battery Replacement: 步骤 25 中的图像 1,1
    • Remove the battery.
结论
To reassemble your Fitbit ionic follow these instructions in reverse.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
7等其他人完成本指南。
Adriana Zwink
于12/18/19注册
63,735 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了24,050篇指南
14指南评论
This guide is very detailed and pretty accurate. Thank you for posting it!
Does anyone know how crucial the ‘Calibration’ procedure noted at the end article is?
I replaced my battery and it drains so quickly - during the course of a few hours.
But I didn’t try leaving it on the charger for 2 hours after 100% is reached. Trying that now.
Monte87 - 回复
Und woher bekommt man die Batterie?
k.krah - 回复
From iFixit.com - they are back in stock now.
Monte87 -
Sehe keine Battery im Shop.
Gibt es einen Link?
k.krah -
The new battery part is linked at the top of this page.
Here is the link: [关联产品丢失或禁用: IF384-004]
- regards
Monte87 -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 84
总计 16,339
