跳转到主内容
加入维修社区 - 创建账户
Fender Starcaster Pickups Replacement
你所需要的
    1. Fender Starcaster Pickups Replacement, Loosen the Strings: 步骤 1 中的图像 1,3 Fender Starcaster Pickups Replacement, Loosen the Strings: 步骤 1 中的图像 2,3 Fender Starcaster Pickups Replacement, Loosen the Strings: 步骤 1 中的图像 3,3
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      询问修复机器人
      添加评论
    2. Fender Starcaster Pickups Replacement, Remove the Strings from the Tuning Pegs: 步骤 2 中的图像 1,2 Fender Starcaster Pickups Replacement, Remove the Strings from the Tuning Pegs: 步骤 2 中的图像 2,2
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      询问修复机器人
      添加评论
    3. Fender Starcaster Pickups Replacement, Remove the Strings from the Bridge: 步骤 3 中的图像 1,3 Fender Starcaster Pickups Replacement, Remove the Strings from the Bridge: 步骤 3 中的图像 2,3 Fender Starcaster Pickups Replacement, Remove the Strings from the Bridge: 步骤 3 中的图像 3,3
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      添加评论
    1. Fender Starcaster Pickups Replacement, Remove the Knobs: 步骤 4 中的图像 1,1
      • While it is not necessary to remove the potentiometer knobs in order to remove the pickguard, it is much easier to remove them while the pickguard is attached to the guitar.
      • The knobs are removed simply by pulling up on them. Be mindful not to pry too much, as older components may feel stuck at first, and you do not want to break the pickguard, knob, or potentiometer.
      询问修复机器人
      添加评论
    2. Fender Starcaster Pickups Replacement, Remove the Selector Switch Cap: 步骤 5 中的图像 1,2 Fender Starcaster Pickups Replacement, Remove the Selector Switch Cap: 步骤 5 中的图像 2,2
      • As with the knobs, the switch cap may be removed prior to removing the pickguard.
      • Grip the cap firmly, and pull up to remove it from the switch. Be aware that the switch may move, and to be careful so that you do not break it.
      询问修复机器人
      添加评论
    3. Fender Starcaster Pickups Replacement: 步骤 6 中的图像 1,2 Fender Starcaster Pickups Replacement: 步骤 6 中的图像 2,2
      • Once the cap and knobs have been removed, you may begin removing the screws around the perimeter of the pickguard.
      • Do not remove the screws on the electronics.
      询问修复机器人
      添加评论
    4. Fender Starcaster Pickups Replacement, Remove the Pickguard: 步骤 7 中的图像 1,3 Fender Starcaster Pickups Replacement, Remove the Pickguard: 步骤 7 中的图像 2,3 Fender Starcaster Pickups Replacement, Remove the Pickguard: 步骤 7 中的图像 3,3
      • Gently lift up on the pickguard. With the screws removed, it should be loose, and easily pulled off of the guitar body.
      • Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack.
      询问修复机器人
      添加评论
    1. Fender Starcaster Pickups Replacement, Pickups: 步骤 8 中的图像 1,2 Fender Starcaster Pickups Replacement, Pickups: 步骤 8 中的图像 2,2
      • Lay the pickguard back down on the guitar body. Take a wrench and unfasten the nuts around the potentiometer posts.
      • Using a screwdriver, remove the screws that secure the selector switch.
      询问修复机器人
      添加评论
    2. Fender Starcaster Pickups Replacement: 步骤 9 中的图像 1,3 Fender Starcaster Pickups Replacement: 步骤 9 中的图像 2,3 Fender Starcaster Pickups Replacement: 步骤 9 中的图像 3,3
      • Remove the screws from the pickups. The screw may not back out all of the way. When you feel it release, move on to the next screw.
      • Once both screws have been freed, you may pull them out of the pickguard.
      • Repeat this for all of the pickups.
      询问修复机器人
      添加评论
    3. Fender Starcaster Pickups Replacement: 步骤 10 中的图像 1,3 Fender Starcaster Pickups Replacement: 步骤 10 中的图像 2,3 Fender Starcaster Pickups Replacement: 步骤 10 中的图像 3,3
      • Now that the electronics have been freed, you may remove the pickguard.
      • Be aware of the pickup retainer springs. These are to ensure that the pickup remains at a proper distance from the strings when it is attached to the pickguard.
      询问修复机器人
      添加评论
    4. Fender Starcaster Pickups Replacement: 步骤 11 中的图像 1,3 Fender Starcaster Pickups Replacement: 步骤 11 中的图像 2,3 Fender Starcaster Pickups Replacement: 步骤 11 中的图像 3,3
      • Heat up a pen-tip, soldering iron and lightly touch the solder on the end of the pickup wire.
      • Gently pull on the pickup wire while melting the solder.
      • After the wire is separated from the selector switch, remove any broken wire strands in the leftover solder with needle-nose pliers, while still heating the solder.
      询问修复机器人
      添加评论
    5. Fender Starcaster Pickups Replacement, Strip New Pickup Wire: 步骤 12 中的图像 1,2 Fender Starcaster Pickups Replacement, Strip New Pickup Wire: 步骤 12 中的图像 2,2
      • Use wire cutters to strip about 1/2" of shielding off the wire.
      询问修复机器人
      添加评论
    6. Fender Starcaster Pickups Replacement, Solder the Pickup Wire: 步骤 13 中的图像 1,3 Fender Starcaster Pickups Replacement, Solder the Pickup Wire: 步骤 13 中的图像 2,3 Fender Starcaster Pickups Replacement, Solder the Pickup Wire: 步骤 13 中的图像 3,3
      • Coat the tip of your soldering iron with new rosin core solder.
      • Heat the wire and coat the exposed pickup wire with a small amount of solder - thus "Tinning" the wire.
      • Melt the solder that is still on the selector switch terminal and quickly remove the excess solder from the terminal. Wrap the tinned wire around the terminal to make a good mechanical connection, before you solder.
      • Press the tip of the soldering iron onto the pickup wire and terminal. Add a little solder, until the solder melts and molds around the wire and terminal. Don't add too much solder (Solder Blob)!
      • Let the solder joint cool and become solid.
      • Lightly tug on the pickup wire to test the strength of the solder connection.
      • If the connection appears solid, reassemble the pickguard in reverse order.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Pasco Hernando, Team 5-3, Prince Fall 2014 Pasco Hernando, Team 5-3, Prince Fall 2014 的会员
PHSC-PRINCE-F14S5G3
9 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 41
总计 4,961
