跳转到主内容
加入维修社区 - 创建账户
Fender Starcaster Bridge Replacement
你所需要的
    1. Fender Starcaster Bridge Replacement, Loosen the Strings: 步骤 1 中的图像 1,3 Fender Starcaster Bridge Replacement, Loosen the Strings: 步骤 1 中的图像 2,3 Fender Starcaster Bridge Replacement, Loosen the Strings: 步骤 1 中的图像 3,3
      • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
      • Repeat this for all six strings on the guitar.
      询问修复机器人
      添加评论
    2. Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: 步骤 2 中的图像 1,2 Fender Starcaster Bridge Replacement, Remove the Strings from the Tuning Pegs: 步骤 2 中的图像 2,2
      • Be mindful of the string ends. They may be sharp and could puncture your skin.
      • It may be necessary to use pliers to remove string ends from the tuning peg.
      询问修复机器人
      添加评论
    3. Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: 步骤 3 中的图像 1,3 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: 步骤 3 中的图像 2,3 Fender Starcaster Bridge Replacement, Remove the Strings from the Bridge: 步骤 3 中的图像 3,3
      • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
      • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
      添加评论
    1. Fender Starcaster Bridge Replacement, Bridge: 步骤 4 中的图像 1,2 Fender Starcaster Bridge Replacement, Bridge: 步骤 4 中的图像 2,2
      • On the back of the guitar, remove the plate covering the spring cavity. In the spring cavity, reduce the tension on the bridge springs by first loosening the retainer screws a bit.
      询问修复机器人
      添加评论
    2. Fender Starcaster Bridge Replacement: 步骤 5 中的图像 1,3 Fender Starcaster Bridge Replacement: 步骤 5 中的图像 2,3 Fender Starcaster Bridge Replacement: 步骤 5 中的图像 3,3
      • To remove the springs from the bridge, grip the end with pliers and pull up.
      • It is safe to use the body of the guitar for leverage.
      询问修复机器人
      添加评论
    3. Fender Starcaster Bridge Replacement: 步骤 6 中的图像 1,3 Fender Starcaster Bridge Replacement: 步骤 6 中的图像 2,3 Fender Starcaster Bridge Replacement: 步骤 6 中的图像 3,3
      • Be aware that the ground wire for the electronics of the guitar is routed through the body and soldered to the spring retainer.
      询问修复机器人
      添加评论
    4. Fender Starcaster Bridge Replacement: 步骤 7 中的图像 1,3 Fender Starcaster Bridge Replacement: 步骤 7 中的图像 2,3 Fender Starcaster Bridge Replacement: 步骤 7 中的图像 3,3
      • Remove the screws from the front of the bridge.
      • It may be helpful to only loosen the outer screws as you remove the inner screws, in order to prevent damage to the guitar.
      询问修复机器人
      添加评论
    5. Fender Starcaster Bridge Replacement: 步骤 8 中的图像 1,1
      • With all six screws removed, lift up on the bridge to remove it from the body.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Pasco Hernando, Team 5-3, Prince Fall 2014 Pasco Hernando, Team 5-3, Prince Fall 2014 的会员
PHSC-PRINCE-F14S5G3
9 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 3,094
