跳转到主内容
加入维修社区 - 创建账户
Fellowes T7CM Shaft Replacement
你所需要的
  1. Fellowes T7CM Shaft Replacement, Fellowes T7CM Casing and Trigger Replacement: 步骤 1 中的图像 1,1
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
    询问修复机器人
    添加评论
  2. Fellowes T7CM Shaft Replacement: 步骤 2 中的图像 1,1
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
    添加评论
  3. Fellowes T7CM Shaft Replacement: 步骤 3 中的图像 1,1
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
    询问修复机器人
    添加评论
  4. Fellowes T7CM Shaft Replacement: 步骤 4 中的图像 1,1
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
    询问修复机器人
    添加评论
  5. Fellowes T7CM Shaft Replacement, Gear and Shaft: 步骤 5 中的图像 1,2 Fellowes T7CM Shaft Replacement, Gear and Shaft: 步骤 5 中的图像 2,2
    • Remove the three screws holding the internal case to the external case. The screw length is 18 mm and the head diameter is 5 mm.
    • Remove the internal case.
    询问修复机器人
    添加评论
  6. Fellowes T7CM Shaft Replacement: 步骤 6 中的图像 1,1
    • Remove the feeding sensor by unscrewing the single screw holding it. The screw length is 10 mm and the head diameter is 6 mm.
    • This step may be unnecessary, but it will prevent the sensor from being damaged.
    询问修复机器人
    添加评论
  7. Fellowes T7CM Shaft Replacement: 步骤 7 中的图像 1,2 Fellowes T7CM Shaft Replacement: 步骤 7 中的图像 2,2
    • Remove the six screws on the gearbox.
    • Remove the gearbox cover to expose the gears.
    • The screw length is 34 mm and the head diameter is 7 mm.
    • The screw length is 26 mm and the head diameter is 7 mm.
    询问修复机器人
    添加评论
  8. Fellowes T7CM Shaft Replacement: 步骤 8 中的图像 1,3 Fellowes T7CM Shaft Replacement: 步骤 8 中的图像 2,3 Fellowes T7CM Shaft Replacement: 步骤 8 中的图像 3,3
    • Remove the gears.
    • The larger gear located in the middle may require a screwdriver to pry off.
    • Remove the gear holder by unscrewing two screws that are holding it in place. The screw length is 14 mm and the head diameter is 5 mm.
    询问修复机器人
    添加评论
  9. Fellowes T7CM Shaft Replacement: 步骤 9 中的图像 1,2 Fellowes T7CM Shaft Replacement: 步骤 9 中的图像 2,2
    • Remove the pin in order to pull the casing off of the shafts.
    • Remove the casing in order to expose shafts.
    添加评论
  10. Fellowes T7CM Shaft Replacement, Shaft: 步骤 10 中的图像 1,1
    • Remove the metal attachment that holds the two shafts together.
    询问修复机器人
    添加评论
  11. Fellowes T7CM Shaft Replacement: 步骤 11 中的图像 1,1
    • The shafts can now be pulled apart and any obstructions located between or on each of the shafts can be removed.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G2
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 32
总计 1,716
