跳转到主内容
加入维修社区 - 创建账户
ExoPC Slate SSD Replacement
你所需要的
  1. ExoPC Slate SSD Replacement, Back Cover and Shield: 步骤 1 中的图像 1,2 ExoPC Slate SSD Replacement, Back Cover and Shield: 步骤 1 中的图像 2,2
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
    询问修复机器人
    添加评论
  2. ExoPC Slate SSD Replacement: 步骤 2 中的图像 1,2 ExoPC Slate SSD Replacement: 步骤 2 中的图像 2,2
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
    询问修复机器人
    添加评论
  3. ExoPC Slate SSD Replacement: 步骤 3 中的图像 1,3 ExoPC Slate SSD Replacement: 步骤 3 中的图像 2,3 ExoPC Slate SSD Replacement: 步骤 3 中的图像 3,3
    • Remove the tape covering the metal shield.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
    询问修复机器人
    添加评论
  4. ExoPC Slate SSD Replacement, SSD: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the two screws using the 0 Phillips screwdriver.
    • Gently pry the SSD from its connector using the tweezers, alternating each side of the SSD until it is free.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team S2-G1, Peak Fall 2018 UMass Dartmouth, Team S2-G1, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G1
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 832
