跳转到主内容
加入维修社区 - 创建账户
Evercade EXP Directional Pad Replacement
你所需要的
  1. Evercade EXP Directional Pad Replacement, Faceplate: 步骤 1 中的图像 1,3 Evercade EXP Directional Pad Replacement, Faceplate: 步骤 1 中的图像 2,3 Evercade EXP Directional Pad Replacement, Faceplate: 步骤 1 中的图像 3,3
    • Lay the device on a flat surface, with the screen facing the sufrace.
    • Using angled tweezers, remove the six rubber screw covers from the sockets.
    • The covers are all identical, so they do not need to be stored separately from one another.
    询问修复机器人
    添加评论
  2. Evercade EXP Directional Pad Replacement: 步骤 2 中的图像 1,3 Evercade EXP Directional Pad Replacement: 步骤 2 中的图像 2,3 Evercade EXP Directional Pad Replacement: 步骤 2 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the six 8 mm screws on the lower case.
    询问修复机器人
    添加评论
  3. Evercade EXP Directional Pad Replacement: 步骤 3 中的图像 1,2 Evercade EXP Directional Pad Replacement: 步骤 3 中的图像 2,2
    • Flip the device so the screen is facing you.
    • Four hidden retaining clips hold the pieces together even near each corner of the screen.
    • Insert a Jimmy into the seam located between the faceplate and the shell.
    • Move the a Jimmy toward the screen until you find the first clasp. Move the handle of the jimmy tool up to pop the faceplate free from the clasp.
    • Repeat until for each of the four clasps to fully release the faceplate from the shell.
    • Do not use excessive force when moving the Jimmy. The plastic may shear if too much force is applied horizontally, and it may snap if too much vertical force is applied.
    询问修复机器人
    添加评论
  4. Evercade EXP Directional Pad Replacement: 步骤 4 中的图像 1,3 Evercade EXP Directional Pad Replacement: 步骤 4 中的图像 2,3 Evercade EXP Directional Pad Replacement: 步骤 4 中的图像 3,3
    • Flip the faceplate away from the shell carefully. The faceplate is still connected to the motherboard via a ribbon cable.
    • Flip up the locking flap securing the display ribbon cable, then use tweezers to disconnect the ribbon cable.
    • Be careful when separating the faceplate from the shell, the buttons are held in place by the connection, so they may fall out when opening the device.
    询问修复机器人
    添加评论
  5. Evercade EXP Directional Pad Replacement, Buttons: 步骤 5 中的图像 1,3 Evercade EXP Directional Pad Replacement, Buttons: 步骤 5 中的图像 2,3 Evercade EXP Directional Pad Replacement, Buttons: 步骤 5 中的图像 3,3
    • Locate the four circular buttons in a diamond shape on the face plate, the two circular buttons placed next to each other, and the two small oval buttons and a circular button in a row near those in a diamond pattern.
    • Using angled tweezer, gently remove the buttons from the face plate. The buttons may fall out, so be ready to catch any that fall from the device before intended removal.
    • The buttons are held in place with the pressure of the shell and faceplate when closed. They should be removed with a nominal amount of force.
    询问修复机器人
    添加评论
  6. Evercade EXP Directional Pad Replacement, Directional Pad: 步骤 6 中的图像 1,2 Evercade EXP Directional Pad Replacement, Directional Pad: 步骤 6 中的图像 2,2
    • The directional pad is composed of two pieces, the back of the button holds the face of the button within a small square hole. The pieces are held together by friction, and do not require very much force to seperate.
    • Using tweezers, pull the face of the directional pad from its socket in the back piece until the two separate.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 42
总计 80
