跳转到主内容
加入维修社区 - 创建账户
Eureka 1660SP External Start Switch Realignment
你所需要的
  1. Eureka 1660SP External Start Switch Realignment, Motor Housing: 步骤 1 中的图像 1,2 Eureka 1660SP External Start Switch Realignment, Motor Housing: 步骤 1 中的图像 2,2
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
    询问修复机器人
    添加评论
  2. Eureka 1660SP External Start Switch Realignment: 步骤 2 中的图像 1,2 Eureka 1660SP External Start Switch Realignment: 步骤 2 中的图像 2,2
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
    询问修复机器人
    添加评论
  3. Eureka 1660SP External Start Switch Realignment: 步骤 3 中的图像 1,3 Eureka 1660SP External Start Switch Realignment: 步骤 3 中的图像 2,3 Eureka 1660SP External Start Switch Realignment: 步骤 3 中的图像 3,3
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
    询问修复机器人
    添加评论
  4. Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: 步骤 4 中的图像 1,3 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: 步骤 4 中的图像 2,3 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: 步骤 4 中的图像 3,3
    • If the external switch is slightly misaligned as shown, realign it with the internal switch.
    • Make sure the spring loaded button on the underside of the housing is intact when reassembling the motor housing. It is prone to eject when opening the motor housing.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Evan Fodi
于09/24/13注册
122 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G1
3 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 2,767
