跳转到主内容
加入维修社区 - 创建账户
Eureka 1660SP Extendable Pole Realignment
你所需要的
    1. Eureka 1660SP Extendable Pole Realignment, Motor Housing: 步骤 1 中的图像 1,2 Eureka 1660SP Extendable Pole Realignment, Motor Housing: 步骤 1 中的图像 2,2
      • Before you start, make sure your vacuum is unplugged the power outlet.
      • Press and hold down the black button below the handle while pulling the pole out.
      询问修复机器人
      添加评论
    2. Eureka 1660SP Extendable Pole Realignment: 步骤 2 中的图像 1,2 Eureka 1660SP Extendable Pole Realignment: 步骤 2 中的图像 2,2
      • Press the black separator switch to separate the top and bottom halves of the vacuum.
      询问修复机器人
      添加评论
    3. Eureka 1660SP Extendable Pole Realignment: 步骤 3 中的图像 1,3 Eureka 1660SP Extendable Pole Realignment: 步骤 3 中的图像 2,3 Eureka 1660SP Extendable Pole Realignment: 步骤 3 中的图像 3,3
      • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
      • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
      • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
      询问修复机器人
      添加评论
    1. Eureka 1660SP Extendable Pole Realignment, Realignment of the extendable pole: 步骤 4 中的图像 1,1
      • Once the housing is open, locate the solid chrome plated piece at the front end of the extendable pole.
      询问修复机器人
      添加评论
    2. Eureka 1660SP Extendable Pole Realignment: 步骤 5 中的图像 1,2 Eureka 1660SP Extendable Pole Realignment: 步骤 5 中的图像 2,2
      • On the side of the motor housing which does not hold the engine, find the center track which runs along the inside of the housing.
      • Re-insert the chrome plated piece into the center track.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Evan Fodi
于09/24/13注册
122 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 的会员
UMASSD-GULBRANDSEN-F13S1G1
3 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 29
总计 825
