跳转到主内容
加入维修社区 - 创建账户
Eton FRX3 Solar Panel Replacement
你所需要的
    1. Eton FRX3 Solar Panel Replacement, Rechargeable Battery Pack: 步骤 1 中的图像 1,1
      • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
      询问修复机器人
      添加评论
    2. Eton FRX3 Solar Panel Replacement: 步骤 2 中的图像 1,1
      • Disconnect the battery pack wires from the device and remove the battery pack.
      询问修复机器人
      添加评论
    1. Eton FRX3 Solar Panel Replacement, Case Assembly: 步骤 3 中的图像 1,1
      • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
      询问修复机器人
      添加评论
    2. Eton FRX3 Solar Panel Replacement: 步骤 4 中的图像 1,1
      • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
      询问修复机器人
      添加评论
    3. Eton FRX3 Solar Panel Replacement: 步骤 5 中的图像 1,1
      • Remove the two Phillips #00 screws located in the center of the back of the device.
      • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
      询问修复机器人
      添加评论
    4. Eton FRX3 Solar Panel Replacement: 步骤 6 中的图像 1,1
      • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
      • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
      询问修复机器人
      添加评论
    5. Eton FRX3 Solar Panel Replacement: 步骤 7 中的图像 1,1
      • Pull the two halves of the device's case apart.
      • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
      询问修复机器人
      添加评论
    1. Eton FRX3 Solar Panel Replacement, Solar Panel: 步骤 8 中的图像 1,1
      • The solar panel is connected to the motherboard through a simple socket, just pull up to unplug.
      询问修复机器人
      添加评论
    2. Eton FRX3 Solar Panel Replacement: 步骤 9 中的图像 1,1
      • The solar panel is not glued or soldered in place, you can simply lift the panel straight up from it’s seating to remove.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016 的会员
USFT-NANCE-S16S1G6
4 名成员
创作了39篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 30
总计 880
