你所需要的
Use a spudger to open and detach the wiring from the box holding the battery.
Insert the flat end of the spudger on both sides of the box, gently pry it open and detach it from the clock.
2等其他人完成本指南。
1指南评论
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
