跳转到主内容
加入维修社区 - 创建账户
Epson VS250 Fan Replacement
你所需要的
    1. Epson VS250 Fan Replacement, Shell: 步骤 1 中的图像 1,1
      • Place the projector on a flat surface.
      • Orient the projector so that the the word "Epson" is facing you.
      • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
      询问修复机器人
      添加评论
    2. Epson VS250 Fan Replacement: 步骤 2 中的图像 1,1
      • Slide the cover to the right and lift the cover up and out to remove.
      询问修复机器人
      添加评论
    3. Epson VS250 Fan Replacement: 步骤 3 中的图像 1,1
      • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
      • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
      询问修复机器人
      添加评论
    4. Epson VS250 Fan Replacement: 步骤 4 中的图像 1,1
      • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
      询问修复机器人
      添加评论
    5. Epson VS250 Fan Replacement: 步骤 5 中的图像 1,2 Epson VS250 Fan Replacement: 步骤 5 中的图像 2,2
      • Flip the projector so that it lays upside down.
      • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
      询问修复机器人
      添加评论
    6. Epson VS250 Fan Replacement: 步骤 6 中的图像 1,1
      • Remove the front cover from the projector by pulling it off of the device.
      询问修复机器人
      添加评论
    7. Epson VS250 Fan Replacement: 步骤 7 中的图像 1,1
      • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
      • After completing this step you will be able to remove the back cover from the projector.
      询问修复机器人
      添加评论
    8. Epson VS250 Fan Replacement: 步骤 8 中的图像 1,1
      • Slowly lift up the top shell up and out of the device.
      • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
      询问修复机器人
      添加评论
    1. Epson VS250 Fan Replacement, Fan: 步骤 9 中的图像 1,1
      • Use a Phillips #1 screwdriver to remove the five 10 mm screws.
      询问修复机器人
      添加评论
    2. Epson VS250 Fan Replacement: 步骤 10 中的图像 1,3 Epson VS250 Fan Replacement: 步骤 10 中的图像 2,3 Epson VS250 Fan Replacement: 步骤 10 中的图像 3,3
      • Unplug the fan connector from the circuit board.
      • Remove the wires from the hooks that secure them to free the fan.
      询问修复机器人
      添加评论
    3. Epson VS250 Fan Replacement: 步骤 11 中的图像 1,2 Epson VS250 Fan Replacement: 步骤 11 中的图像 2,2
      • Disconnect the wire and remove the black casing from the rest of the fan assembly.
      询问修复机器人
      添加评论
    4. Epson VS250 Fan Replacement: 步骤 12 中的图像 1,2 Epson VS250 Fan Replacement: 步骤 12 中的图像 2,2
      • Remove the fan from the device.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Warren Cutlip
于09/28/21注册
604 声望
创作了5篇指南
团队
Clemson, Team 4-2, Hunter Fall 2021 Clemson, Team 4-2, Hunter Fall 2021 的会员
CLEM-HUNTER-F21S4G2
5 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 34
总计 757
