跳转到主内容
加入维修社区 - 创建账户
Epson Powerlite 460 Lens Replacement
你所需要的
    1. Epson Powerlite 460 Lens Replacement, Motherboard: 步骤 1 中的图像 1,2 Epson Powerlite 460 Lens Replacement, Motherboard: 步骤 1 中的图像 2,2
      • Orient the device so that the projection window is facing down and the bottom of the device is visible.
      • Remove the eleven 13.3mm screws using a Phillips #2 screwdriver.
      询问修复机器人
      添加评论
    2. Epson Powerlite 460 Lens Replacement: 步骤 2 中的图像 1,3 Epson Powerlite 460 Lens Replacement: 步骤 2 中的图像 2,3 Epson Powerlite 460 Lens Replacement: 步骤 2 中的图像 3,3
      • Flip the device over so that the projection window is facing up.
      • Slide the air filter cover opener in the direction indicated by the arrow to release the air filter cover.
      • Remove the air filter cover.
      询问修复机器人
      添加评论
    3. Epson Powerlite 460 Lens Replacement: 步骤 3 中的图像 1,2 Epson Powerlite 460 Lens Replacement: 步骤 3 中的图像 2,2
      • Remove the two 13.3mm screws from the top cover above the air filter using a Phillips #2 screwdriver.
      • Remove one 13.3mm screw from above the connection panel using a Phillips #2 screwdriver.
      询问修复机器人
      添加评论
    4. Epson Powerlite 460 Lens Replacement: 步骤 4 中的图像 1,2 Epson Powerlite 460 Lens Replacement: 步骤 4 中的图像 2,2
      • Remove the cover from the projector and set aside.
      • The cover will be connected by ribbon cables. You do not need to disconnect these to complete this repair, but it may make it easier.
      询问修复机器人
      添加评论
    5. Epson Powerlite 460 Lens Replacement: 步骤 5 中的图像 1,3 Epson Powerlite 460 Lens Replacement: 步骤 5 中的图像 2,3 Epson Powerlite 460 Lens Replacement: 步骤 5 中的图像 3,3
      • Use the opening tool to disconnect eleven clip cables on the motherboard.
      • These will be the colorful cables connected with white plastic clips.
      • Disconnect the black cable clip by pressing the side tabs. Use the opening tool to release the cable if it is difficult.
      • To disconnect the ribbon cables, use the opening tool to lift the locking flap on the connector and slide the cable back and out of the connector.
      询问修复机器人
      添加评论
    6. Epson Powerlite 460 Lens Replacement: 步骤 6 中的图像 1,1
      • Disconnect the clip cable from below the motherboard and behind the connection panel.
      询问修复机器人
      添加评论
    7. Epson Powerlite 460 Lens Replacement: 步骤 7 中的图像 1,3 Epson Powerlite 460 Lens Replacement: 步骤 7 中的图像 2,3 Epson Powerlite 460 Lens Replacement: 步骤 7 中的图像 3,3
      • Remove seven 8.1mm screws from the motherboard using a Phillips #2 screwdriver.
      • Remove the 8.1mm screw from the back of the projection panel below the motherboard using a Phillips #2 screwdriver.
      • Remove two 8.1mm screws from the front of the projection panel using a Phillips #2 screwdriver.
      询问修复机器人
      添加评论
    8. Epson Powerlite 460 Lens Replacement: 步骤 8 中的图像 1,1
      • Gently lift the motherboard out of the device.
      询问修复机器人
      添加评论
    1. Epson Powerlite 460 Lens Replacement, Lens: 步骤 9 中的图像 1,2 Epson Powerlite 460 Lens Replacement, Lens: 步骤 9 中的图像 2,2
      • Use a Phillips #0 screwdriver to remove the two 9.1mm screws from the focus lever adjuster.
      • Remove the focus lever mechanism by sliding the metal rod out of the plastic lever and lifting out of the unit.
      询问修复机器人
      添加评论
    2. Epson Powerlite 460 Lens Replacement: 步骤 10 中的图像 1,2 Epson Powerlite 460 Lens Replacement: 步骤 10 中的图像 2,2
      • Remove the two 13.3mm screws from the metal bracket surrounding the lens unit using a Phillips #0 screwdriver.
      • Remove the bracket.
      询问修复机器人
      添加评论
    3. Epson Powerlite 460 Lens Replacement: 步骤 11 中的图像 1,2 Epson Powerlite 460 Lens Replacement: 步骤 11 中的图像 2,2
      • Remove the two 13.3mm screws from the lens cover using a Phillips #0 screwdriver.
      • Use your finger to release the clips on either side of the lens cover.
      • Lift the lens cover to remove it from the projector.
      询问修复机器人
      添加评论
    4. Epson Powerlite 460 Lens Replacement: 步骤 12 中的图像 1,2 Epson Powerlite 460 Lens Replacement: 步骤 12 中的图像 2,2
      • Remove the five 9.4mm screws from the lens using a Phillips #0 screwdriver.
      • Lift the lens out of the unit.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 443
