跳转到主内容
加入维修社区 - 创建账户
Epson EX90 Cooling Fan Replacement
你所需要的
    1. Epson EX90 Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 1,2 Epson EX90 Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 2,2
      • Place the projector so that the bottom side is facing upwards
      • Remove the eight screws pictured from the bottom of the device.
      • Open the cover.
      • Be careful when opening the cover; a ribbon cable is still connecting the cover to the motherboard.
      询问修复机器人
      添加评论
    2. Epson EX90 Cooling Fan Replacement: 步骤 2 中的图像 1,1
      • Carefully remove the two parallel wire connectors which connect the fan to the corner of the motherboard.
      • Take care to record the port which each wire comes from, so as not to get your wires crossed.
      询问修复机器人
      添加评论
    3. Epson EX90 Cooling Fan Replacement: 步骤 3 中的图像 1,1
      • Remove the three screws pictured, which hold the fan's frame in place.
      询问修复机器人
      添加评论
    4. Epson EX90 Cooling Fan Replacement: 步骤 4 中的图像 1,2 Epson EX90 Cooling Fan Replacement: 步骤 4 中的图像 2,2
      • Remove fan and related assembly from projector.
      • Detach fan from housing.
      • If the fan is still in good condition, use a paper towel or cloth and clean out all the dust on your fan before reassembling.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Lucas Ketchie
于04/01/22注册
160 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-3, Mellen Spring 2022 UMass Dartmouth, Team 2-3, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G3
4 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 468
