简介
This guide covers the diagnosis of epee point issues and provides instructions for common part replacements to address them.
This guide only deals with issues related to the contact spring and pressure spring. Spring issues can be diagnosed using the weights and shims tests. In this guide shims will be referred to as test gauges.
This guide uses the NEPS screw system but will work for any standard epee screw system.
你所需要的
Plug the epee body cord into the socket on one end and the test box on the other.
Hold your epee upright and place the weight gently onto the point.
The tip may depress beneath the weight. If it does not, press down on the top of the weight.
The green light on the test box should light up, then turn off.
If you fail the smaller test gauge this means that your contact spring is too long. Twist the contact spring a rotation or two up the post.
If you fail the larger test gauge, this means that your contact spring is too short. Gently stretch the spring, or replace it entirely.
To remove the contact spring, pull it off the post. The post is the small threaded cylinder sticking out from the tip.
Twist a new spring onto the post while applying pressure. Make sure your new spring catches on the grooves of the post.
Place the tip back onto the barrel, ensuring that the contact spring is sitting inside the pressure spring.
While holding the tip in place, pick up the NEPS screw with the tip of your NEPS screwdriver.
Depress the tip and rotate it so that the threaded hole in the tip, meant for the tip screw, aligns with the channel on the point barrel.
Insert the NEPS screw with the tip of your screwdriver and tighten it clockwise.
If your weapon is still failing tests, or if the red light on your test box is turning on, your issue is outside the scope of this guide.
