跳转到主内容
加入维修社区 - 创建账户
Emerson Ceiling Fan Flywheel Replacement
你所需要的
    1. Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: 步骤 1 中的图像 1,3 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: 步骤 1 中的图像 2,3 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: 步骤 1 中的图像 3,3
      • Make sure power to the ceiling fan is off!
      • Use a Phillips #0 screwdriver to remove the ten 12.7 mm screws from the ceiling fan blades.
      • It is easier to work on the ceiling fan if you remove the motor.
      询问修复机器人
      添加评论
    2. Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: 步骤 2 中的图像 1,2 Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: 步骤 2 中的图像 2,2
      • Remove light bulbs before working on switch housing.
      • Open the switch housing using a Phillips #0 screwdriver to remove the three 7.9 mm screws.
      询问修复机器人
      添加评论
    3. Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: 步骤 3 中的图像 1,2 Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: 步骤 3 中的图像 2,2
      • Disconnect wires that are attached to the switch housing and the motor.
      • Make sure you know where to reconnect them.
      询问修复机器人
      添加评论
    4. Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: 步骤 4 中的图像 1,3 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: 步骤 4 中的图像 2,3 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: 步骤 4 中的图像 3,3
      • Remove the broken flywheel.
      • Make note of its exact placement on the shaft.
      • It may be a good idea to mark the location with a marker.
      询问修复机器人
      添加评论
    5. Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: 步骤 5 中的图像 1,3 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: 步骤 5 中的图像 2,3 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: 步骤 5 中的图像 3,3
      • Slide the new flywheel into place making sure all the holes line up.
      • Place any wires through the same holes as they were before
      • Replace any other parts you removed during the process.
      询问修复机器人
      添加评论
    6. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: 步骤 6 中的图像 1,2 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: 步骤 6 中的图像 2,2
      • Reconnect the wires from the switch housing to the motor.
      • Make sure you connect the wires to the correct match.
      询问修复机器人
      添加评论
    7. Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: 步骤 7 中的图像 1,3 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: 步骤 7 中的图像 2,3 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: 步骤 7 中的图像 3,3
      • Screw back on the three 7.9 mm screws to the switch housing using a Phillips #0 screwdriver.
      • Screw the light bulbs back in.
      询问修复机器人
      添加评论
    8. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: 步骤 8 中的图像 1,3 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: 步骤 8 中的图像 2,3 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: 步骤 8 中的图像 3,3
      • Using a Phillips #0 screwdriver, reconnect ceiling fan blades by re-screwing on ten 12.7 mm Phillip screws.
      • If you removed the motor, reconnect it after blades are on.
      询问修复机器人
      添加评论
结论
Test your fan. It should be running quietly with no problems. If something is wrong make sure to double check you hooked the wires up correctly.
取消:我没有完成这个指南。
2等其他人完成本指南。
Tanner Brook
于10/21/19注册
199 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 50
总计 5,254
