跳转到主内容
加入维修社区 - 创建账户
Ematic Genesis Camera Replacement
你所需要的
    1. Ematic Genesis Camera Replacement, Ematic Genesis Casing: 步骤 1 中的图像 1,3 Ematic Genesis Camera Replacement, Ematic Genesis Casing: 步骤 1 中的图像 2,3 Ematic Genesis Camera Replacement, Ematic Genesis Casing: 步骤 1 中的图像 3,3
      • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
      询问修复机器人
      添加评论
    2. Ematic Genesis Camera Replacement: 步骤 2 中的图像 1,3 Ematic Genesis Camera Replacement: 步骤 2 中的图像 2,3 Ematic Genesis Camera Replacement: 步骤 2 中的图像 3,3
      • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
      • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
      • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
      • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
      询问修复机器人
      添加评论
    3. Ematic Genesis Camera Replacement: 步骤 3 中的图像 1,1
      • Remove back plate from screen plate and lay both down flat next to each other.
      询问修复机器人
      添加评论
    1. Ematic Genesis Camera Replacement, Camera: 步骤 4 中的图像 1,2 Ematic Genesis Camera Replacement, Camera: 步骤 4 中的图像 2,2
      • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
      询问修复机器人
      添加评论
    2. Ematic Genesis Camera Replacement: 步骤 5 中的图像 1,2 Ematic Genesis Camera Replacement: 步骤 5 中的图像 2,2
      • Lift up the black lever of the connector that holds the camera ribbon in place.
      询问修复机器人
      添加评论
    3. Ematic Genesis Camera Replacement: 步骤 6 中的图像 1,2 Ematic Genesis Camera Replacement: 步骤 6 中的图像 2,2
      • Gently pull the ribbon out of the connector and lift the camera out of the casing.
      • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G3
3 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 36
总计 474
