跳转到主内容
加入维修社区 - 创建账户
Ematic FunTab 3 Touch Screen Replacement
你所需要的
  1. Ematic FunTab 3 Touch Screen Replacement, Back Panel: 步骤 1 中的图像 1,3 Ematic FunTab 3 Touch Screen Replacement, Back Panel: 步骤 1 中的图像 2,3 Ematic FunTab 3 Touch Screen Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
    询问修复机器人
    添加评论
  2. Ematic FunTab 3 Touch Screen Replacement: 步骤 2 中的图像 1,1
    • Pull the back panel away from the screen.
    询问修复机器人
    添加评论
  3. Ematic FunTab 3 Touch Screen Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Remove the black tape to reveal the screen connector.
    询问修复机器人
    添加评论
  4. Ematic FunTab 3 Touch Screen Replacement: 步骤 4 中的图像 1,2 Ematic FunTab 3 Touch Screen Replacement: 步骤 4 中的图像 2,2
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
    询问修复机器人
    添加评论
  5. Ematic FunTab 3 Touch Screen Replacement: 步骤 5 中的图像 1,2 Ematic FunTab 3 Touch Screen Replacement: 步骤 5 中的图像 2,2
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
    询问修复机器人
    添加评论
  6. Ematic FunTab 3 Touch Screen Replacement: 步骤 6 中的图像 1,1
    • It is now safe to remove and replace the old motherboard with your new motherboard.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
    询问修复机器人
    添加评论
  7. Ematic FunTab 3 Touch Screen Replacement, Touch Screen: 步骤 7 中的图像 1,2 Ematic FunTab 3 Touch Screen Replacement, Touch Screen: 步骤 7 中的图像 2,2
    • Insert the hook side of the opening tool between the case and display.
    • Press down on the tool until the screen is clear of the white retaining tabs.
    • Use the plastic opening tool to gently pry up the screen.
    • This is best done on the corner closest to the wire ribbon.
    • Continue prying around the screen until the screen pops out.
    询问修复机器人
    添加评论
  8. Ematic FunTab 3 Touch Screen Replacement: 步骤 8 中的图像 1,1
    • After the screen has come lose, remove it from the device.
    • When reassembling, make sure the screen locks in place, this may require extra pressure
    添加评论
结论
取消:我没有完成这个指南。
Amanda Davis
于07/11/18注册
581 声望
创作了5篇指南
团队
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 的会员
UWT-CARDINAL-SU18S1G5
4 名成员
创作了12篇指南
1指南评论
Where can I get a new display for my emoticons funtab 3?
DanTheMan RBLX - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 1,235
