跳转到主内容
加入维修社区 - 创建账户
Ematic EGQ307 Front Facing Camera Replacement
你所需要的
  1. Ematic EGQ307 Front Facing Camera Replacement, Front Facing Camera: 步骤 1 中的图像 1,1
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
    询问修复机器人
    添加评论
  2. Ematic EGQ307 Front Facing Camera Replacement: 步骤 2 中的图像 1,2 Ematic EGQ307 Front Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
    询问修复机器人
    添加评论
  3. Ematic EGQ307 Front Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Once you pry off the plastic backing, you will expose the battery and the motherboard.
    询问修复机器人
    添加评论
  4. Ematic EGQ307 Front Facing Camera Replacement: 步骤 4 中的图像 1,2 Ematic EGQ307 Front Facing Camera Replacement: 步骤 4 中的图像 2,2
    • carefully pry off the plastic backing, remove the tape over the camera.
    • When working with device, make sure the battery is dead and there is not plugged in to the charger to limit the risk of shock.
    询问修复机器人
    添加评论
  5. Ematic EGQ307 Front Facing Camera Replacement: 步骤 5 中的图像 1,2 Ematic EGQ307 Front Facing Camera Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the tape holding the camera in place as the camera is attached to the backing of the tape.
    • Gently lift up the black lever that’s holding the camera ribbon in place using the spudger tools.
    • Once lever is lifted up, remove camera from device; and it is ready to be replaced.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 18
总计 566
