简介
If your digitizer is no longer responding to your touch or is cracked then you may need to replace it, this guide with teach you exactly how to replace your tablets digitizer.
你所需要的
There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
在这个步骤中使用的工具:Plastic Cards$2.99
Once you pry off the plastic backing, you will expose the battery and the motherboard.
Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LCD.
Pry the battery off the LCD using a flat and rigid piece of plastic, such as the plastic card.
另外一个人完成了本指南。
