跳转到主内容
加入维修社区 - 创建账户
Element GC-1020 Display Replacement
你所需要的
    1. Element GC-1020 Display Replacement, Back Cover Replacement Guide: 步骤 1 中的图像 1,1
      • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
      询问修复机器人
      添加评论
    2. Element GC-1020 Display Replacement: 步骤 2 中的图像 1,1
      • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
      • If you pull back too forcefully the power button would move out of place.
      询问修复机器人
      添加评论
    1. Element GC-1020 Display Replacement, Display: 步骤 3 中的图像 1,1
      • Unscrew the visible Philips head screws (size: 3.968 mm) on the motherboard located on the top of left and right sides. Use a PH #0 sized screw driver head for removal.
      询问修复机器人
      添加评论
    2. Element GC-1020 Display Replacement: 步骤 4 中的图像 1,2 Element GC-1020 Display Replacement: 步骤 4 中的图像 2,2
      • Carefully bend the plastic frame to remove the motherboard.
      • Upon doing this make sure your power button on the bottom left side stays attached to the outer frame because it will loosen as the motherboard is moved upwards.
      询问修复机器人
      添加评论
    3. Element GC-1020 Display Replacement: 步骤 5 中的图像 1,1
      • The display is attached to a dark yellow, flimsy, plastic material. This material is then attached to the motherboard. Tear off the plastic, successfully detaching the motherboard and display from each other.
      询问修复机器人
      添加评论
    4. Element GC-1020 Display Replacement: 步骤 6 中的图像 1,3 Element GC-1020 Display Replacement: 步骤 6 中的图像 2,3 Element GC-1020 Display Replacement: 步骤 6 中的图像 3,3
      • Once the display is by itself, separate from the rest of the device, you are ready to put in your new display.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Lashaun Noel
于09/25/15注册
591 声望
创作了5篇指南
团队
1指南评论
but can i ask do you know how to reboot the software ?
i mean we try to put in our music or video or image inside. can it be done
Nisha Najihah - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 50
总计 699
