跳转到主内容
加入维修社区 - 创建账户
Eightarc Fusion USB Cable Replacement
你所需要的
    1. Eightarc Fusion USB Cable Replacement, USB Cable: 步骤 1 中的图像 1,2 Eightarc Fusion USB Cable Replacement, USB Cable: 步骤 1 中的图像 2,2
      • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
      • Place the controller face down (buttons and joystick down).
      • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
      • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
      询问修复机器人
      添加评论
    2. Eightarc Fusion USB Cable Replacement: 步骤 2 中的图像 1,1
      • Open the door for the cord storage compartment on the right side of the device.
      • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
      询问修复机器人
      添加评论
    3. Eightarc Fusion USB Cable Replacement: 步骤 3 中的图像 1,1
      • With flap unlatched, gently bend the flap and pull slightly to get the pegs out of the socket
      • Be sure to be gentle and not snap the plastic flap in half.
      询问修复机器人
      添加评论
    4. Eightarc Fusion USB Cable Replacement: 步骤 4 中的图像 1,1
      • Slide USB cable up from the plastic barrier casing.
      询问修复机器人
      添加评论
    5. Eightarc Fusion USB Cable Replacement: 步骤 5 中的图像 1,3 Eightarc Fusion USB Cable Replacement: 步骤 5 中的图像 2,3 Eightarc Fusion USB Cable Replacement: 步骤 5 中的图像 3,3
      • The USB cord is connected to the logic board by a plastic plug with five wires.
      • Gently pull up and wiggle the white plastic end attached to the wires out of the mother board.
      • The white casing on top pulls off from its counterpart on the logic board. Do not take off the bottom part of the white fixture from the logic board.
      • Remove USB cable from device.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Dana
于02/01/15注册
141 声望
撰写一个指南
团队
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G35
4 名成员
创作了60篇指南
1指南评论
Where do I get the USB wire?
desmond.bouey1 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 41
总计 1,274
