跳转到主内容
加入维修社区 - 创建账户
Eightarc Fusion Button Replacement
你所需要的
    1. Eightarc Fusion Button Replacement, Buttons: 步骤 1 中的图像 1,1
      • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface, or prop the controller up to avoid stress on the joystick.
      • Place the controller face down (buttons and joystick down).
      • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
      • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
      询问修复机器人
      添加评论
    2. Eightarc Fusion Button Replacement: 步骤 2 中的图像 1,1
      • Open the door for the cord storage compartment on the right side of the device.
      • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
      询问修复机器人
      添加评论
    3. Eightarc Fusion Button Replacement: 步骤 3 中的图像 1,1
      • Remove the clear rubber casing around the wire connector by lifting the casing up and moving it up along the wire.
      • Repeat for second clear rubber casing.
      询问修复机器人
      添加评论
    4. Eightarc Fusion Button Replacement: 步骤 4 中的图像 1,2 Eightarc Fusion Button Replacement: 步骤 4 中的图像 2,2
      • Gently grasp and lift up on the metal section of the wire to remove the wire from the button connector.
      • A slight wiggling motion might help remove the wire from the connector.
      • Make sure to keep track of which wires go to what button slot location.
      询问修复机器人
      添加评论
    5. Eightarc Fusion Button Replacement: 步骤 5 中的图像 1,2 Eightarc Fusion Button Replacement: 步骤 5 中的图像 2,2
      • Gently depress the two plastic tabs on both of the sides of the button casing.
      • The plastic tabs on the buttons are extremely fragile, handle with care.
      • Slightly push the button down, out of the controller until it slides out.
      • During re-assembly, make sure the button tabs align with the slots in the casing when inserting the button back in.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Austin
于01/28/15注册
245 声望
创作了2篇指南
团队
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G35
4 名成员
创作了60篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 36
总计 1,166
