跳转到主内容
加入维修社区 - 创建账户
Dyson V8 Absolute Battery Replacement
你所需要的
  1. Dyson V8 Absolute Battery Replacement, Battery: 步骤 1 中的图像 1,2 Dyson V8 Absolute Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Detach wand from device.
    • Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
    • Screw Head Type: Phillips #2
    • Screw Length: 170mm
    询问修复机器人
    添加评论
  2. Dyson V8 Absolute Battery Replacement: 步骤 2 中的图像 1,3 Dyson V8 Absolute Battery Replacement: 步骤 2 中的图像 2,3 Dyson V8 Absolute Battery Replacement: 步骤 2 中的图像 3,3
    • Turn device completely over to view battery pack.
    • Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery pack.
    询问修复机器人
    添加评论
  3. Dyson V8 Absolute Battery Replacement: 步骤 3 中的图像 1,3 Dyson V8 Absolute Battery Replacement: 步骤 3 中的图像 2,3 Dyson V8 Absolute Battery Replacement: 步骤 3 中的图像 3,3
    • Pull the battery pack down and away from the device.
    • Battery pack may fall out.
    添加评论
结论
取消:我没有完成这个指南。
61等其他人完成本指南。
Jasvir Dosanjh
于10/25/17注册
1,959 声望
撰写一个指南
团队
UW Tacoma, Team S1-G5, Rose Fall 2017 UW Tacoma, Team S1-G5, Rose Fall 2017 的会员
UWT-ROSE-F17S1G5
4 名成员
创作了21篇指南
18指南评论
Great instructions!!
akcosta60 - 回复 分享
I have replaced the battery and I still got a flashing red light, any ideas
georgewaterson - 回复 分享
I replaced my battery and charged the new one- my vac doesnt work
grooveon.g - 回复 分享
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
anthony richards - 回复 分享
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
Trunker Trubshaw - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 74
过去 7 天: 421
过去 30 天: 1,877
总计 215,771
