跳转到主内容
加入维修社区 - 创建账户
Dyson DC58 Main Body Replacement
你所需要的
视频概述
    1. Dyson DC58 Main Body Replacement, Bin: 步骤 1 中的图像 1,1
      • Make sure your vacuum is unplugged.
      • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
      询问修复机器人
      添加评论
    2. Dyson DC58 Main Body Replacement: 步骤 2 中的图像 1,1
      • Locate the red lever parallel to the red trigger and on the side of the clear bin.
      询问修复机器人
      添加评论
    3. Dyson DC58 Main Body Replacement: 步骤 3 中的图像 1,1
      • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
      询问修复机器人
      添加评论
    4. Dyson DC58 Main Body Replacement: 步骤 4 中的图像 1,2 Dyson DC58 Main Body Replacement: 步骤 4 中的图像 2,2
      • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
      询问修复机器人
      添加评论
    1. Dyson DC58 Main Body Replacement, Main Body: 步骤 5 中的图像 1,1
      • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
      询问修复机器人
      添加评论
    2. Dyson DC58 Main Body Replacement: 步骤 6 中的图像 1,2 Dyson DC58 Main Body Replacement: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
      • Use tweezers to pinch the two visible white clips together.
      • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
      询问修复机器人
      添加评论
    3. Dyson DC58 Main Body Replacement: 步骤 7 中的图像 1,1
      • Tilt and pull the main body away from the purple cyclone of the vacuum.
      • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
Krista St Onge
于09/17/15注册
2,260 声望
创作了2篇指南
团队
CSU Fullerton, Team 2-4, Bruce Fall 2015 CSU Fullerton, Team 2-4, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S2G4
4 名成员
创作了24篇指南
4指南评论
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - 回复 分享
Has anyone replaced the red release catch?
chrisashton1 - 回复 分享
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - 回复 分享
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 74
总计 14,678
