跳转到主内容
加入维修社区 - 创建账户
Dyson DC39 Origin Cyclone Filter Replacement
你所需要的
  1. Dyson DC39 Origin Cyclone Filter Replacement, Bin: 步骤 1 中的图像 1,3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: 步骤 1 中的图像 2,3 Dyson DC39 Origin Cyclone Filter Replacement, Bin: 步骤 1 中的图像 3,3
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
    询问修复机器人
    添加评论
  2. Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: 步骤 2 中的图像 1,3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: 步骤 2 中的图像 2,3 Dyson DC39 Origin Cyclone Filter Replacement, Pre-filter: 步骤 2 中的图像 3,3
    • Remove the purple pre-filter by pulling it up and out of the bin.
    询问修复机器人
    添加评论
  3. Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: 步骤 3 中的图像 1,2 Dyson DC39 Origin Cyclone Filter Replacement, Cyclone Filter: 步骤 3 中的图像 2,2
    • Push down on the red button, located on top of the bin, to release the bottom section of the bin.
    询问修复机器人
    添加评论
  4. Dyson DC39 Origin Cyclone Filter Replacement: 步骤 4 中的图像 1,1
    • Push the grey button located in between the parts of the red lever to release the clear, bottom section of the bin.
    • The grey button can only be pressed after the bottom section is open.
    询问修复机器人
    添加评论
  5. Dyson DC39 Origin Cyclone Filter Replacement: 步骤 5 中的图像 1,3 Dyson DC39 Origin Cyclone Filter Replacement: 步骤 5 中的图像 2,3 Dyson DC39 Origin Cyclone Filter Replacement: 步骤 5 中的图像 3,3
    • You should notice several notches around the rim of the filter. Slide the plastic opening tool around the rim to release the notches.
    • After releasing all of the notches, pull the filter away from the orange cyclone assembly to remove it from the bin.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Sam Nelson
于04/26/17注册
167 声望
撰写一个指南
团队
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G6
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 49
总计 4,033
