跳转到主内容
加入维修社区 - 创建账户
Dyson DC39 Origin Ball Wheels Replacement
你所需要的
    1. Dyson DC39 Origin Ball Wheels Replacement, Bin: 步骤 1 中的图像 1,3 Dyson DC39 Origin Ball Wheels Replacement, Bin: 步骤 1 中的图像 2,3 Dyson DC39 Origin Ball Wheels Replacement, Bin: 步骤 1 中的图像 3,3
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      询问修复机器人
      添加评论
    1. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: 步骤 2 中的图像 1,3 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: 步骤 2 中的图像 2,3 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: 步骤 2 中的图像 3,3
      • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
      • Remove the four 18.0 mm Torx 15 screws.
      询问修复机器人
      添加评论
    2. Dyson DC39 Origin Ball Wheels Replacement: 步骤 3 中的图像 1,3 Dyson DC39 Origin Ball Wheels Replacement: 步骤 3 中的图像 2,3 Dyson DC39 Origin Ball Wheels Replacement: 步骤 3 中的图像 3,3
      • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
      • Hold the steering assembly base near one of the wheels.
      • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
      • Push up on the steering assembly to remove it completely from the ball housing.
      • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
      询问修复机器人
      添加评论
    1. Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: 步骤 4 中的图像 1,2 Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: 步骤 4 中的图像 2,2
      • Remove the 21.4 mm Torx 15 screw located at the center of the ball wheel.
      • There is one screw located at the center of each wheel.
      询问修复机器人
      添加评论
    2. Dyson DC39 Origin Ball Wheels Replacement: 步骤 5 中的图像 1,3 Dyson DC39 Origin Ball Wheels Replacement: 步骤 5 中的图像 2,3 Dyson DC39 Origin Ball Wheels Replacement: 步骤 5 中的图像 3,3
      • Pull the wheel away from the main body of the device.
      • This may require a lot of force. The plastic wheel may bend slightly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G6
3 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 37
总计 2,673
