跳转到主内容
加入维修社区 - 创建账户
Dyson DC39 Origin Replacement
你所需要的
    1. Dyson DC39 Origin  Replacement, Bin: 步骤 1 中的图像 1,3 Dyson DC39 Origin  Replacement, Bin: 步骤 1 中的图像 2,3 Dyson DC39 Origin  Replacement, Bin: 步骤 1 中的图像 3,3
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      询问修复机器人
      添加评论
    1. Dyson DC39 Origin  Replacement, Steering Assembly: 步骤 2 中的图像 1,3 Dyson DC39 Origin  Replacement, Steering Assembly: 步骤 2 中的图像 2,3 Dyson DC39 Origin  Replacement, Steering Assembly: 步骤 2 中的图像 3,3
      • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
      • Remove the four 18.0 mm Torx 15 screws.
      询问修复机器人
      添加评论
    2. Dyson DC39 Origin  Replacement: 步骤 3 中的图像 1,3 Dyson DC39 Origin  Replacement: 步骤 3 中的图像 2,3 Dyson DC39 Origin  Replacement: 步骤 3 中的图像 3,3
      • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
      • Hold the steering assembly base near one of the wheels.
      • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
      • Push up on the steering assembly to remove it completely from the ball housing.
      • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
      询问修复机器人
      添加评论
    1. Dyson DC39 Origin  Replacement, Inlet Hose: 步骤 4 中的图像 1,2 Dyson DC39 Origin  Replacement, Inlet Hose: 步骤 4 中的图像 2,2
      • Remove the two 17.8 mm Phillips #2 screws located in the top of the inlet hose bracket.
      • Remove the two 13.7 mm Torx 8 screws located at the opposite end of the inlet hose.
      • The Torx 8 screws are located at an odd angle. Be sure the screwdriver is secure to prevent stripping the screws.
      询问修复机器人
      添加评论
    2. Dyson DC39 Origin  Replacement: 步骤 5 中的图像 1,2 Dyson DC39 Origin  Replacement: 步骤 5 中的图像 2,2
      • Pull the inlet hose straight up from the steering assembly.
      • The inlet hose 'snaps' out of its position, so you may have to apply a little extra force while pulling.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team S23-G6, Livingston Spring 2017 Cal Poly, Team S23-G6, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G6
3 名成员
创作了12篇指南
1指南评论
Really clear instructions - thank you
collette - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 42
总计 4,817
