跳转到主内容
加入维修社区 - 创建账户
Dyson DC14 Power Switch Replacement
你所需要的
  1. Dyson DC14 Power Switch Replacement, Power Switch: 步骤 1 中的图像 1,2 Dyson DC14 Power Switch Replacement, Power Switch: 步骤 1 中的图像 2,2
    • Start with your Dyson DC14 unplugged, standing upright and facing towards you.
    • Remove the canister from the vacuum.
    • Disconnect the telescopic vacuum wand.
    • Remove the two T15 Torx screws securing the switch cover to the vacuum.
    询问修复机器人
    添加评论
  2. Dyson DC14 Power Switch Replacement: 步骤 2 中的图像 1,2 Dyson DC14 Power Switch Replacement: 步骤 2 中的图像 2,2
    • Push outward on the two plastic clips that secure the switch cover to the vacuum.
    添加评论
  3. Dyson DC14 Power Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the switch cover from the vacuum.
    • The purple switch button may separate from the rest of the switch cover.
    询问修复机器人
    添加评论
  4. Dyson DC14 Power Switch Replacement: 步骤 4 中的图像 1,1
    • Holding them by their white plastic coverings, firmly pull the two wires from the power switch.
    • Be sure to grip the wires from their attached connectors. Pulling directly on the wires could damage your vacuum.
    • The terminals will only fit one way during reassembly. Only one of the wires is long enough to reach the far terminal of the switch.
    添加评论
结论
取消:我没有完成这个指南。
19等其他人完成本指南。
Zachary
于10/06/12注册
318 声望
撰写一个指南
团队
Cal Poly, Team 3-22, Amido Fall 2012 Cal Poly, Team 3-22, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G22
4 名成员
创作了14篇指南
10指南评论
Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!
Tim Swift - 回复 分享
The comment I listed below is not mine. I copied it from a Mr. Tim Swift who wrote it on 06/28/2015. Had I not have seen his comment, I would have said the exact same thing.
I have only one other thing to say......AWESOME!!
Bob Williams
robertvwilliams@comcast.net
"Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!"
Robert Williams - 回复 分享
I replaced my power switch. Easy! $15 part!
brdurham - 回复 分享
Thanks from a 70 year old non-mechanical female with no torque wrench. I followed this tutorial a few months ago and found that my switch had simply come undone and I reinserted it but couldn't attach orange thing back cause switch kept slipping loose. I taped it up around switch so I wouldn't get electrocuted when turning on. Has worked fine til now, and I suppose my switch has finally failed, so I'm ordering new one. This Dyson was a refurbished one I got fairly cheap (for a Dyson) 12 years ago! SO, THANKS MUCH!!
Queenie - 回复 分享
Brilliant and saved me over £100 which is the cost of a Dyson engineer to attend plus switch. Name a charity.
Tariq Rafique - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 65
总计 39,521
