当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
依照本指南来更换Dualshock 4控制器 (CUH-ZCT1U) 的任何的按键。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
Slide your pick toward the handle and pry up to release the first clip.
Repeat this procedure on the other side of the controller to release the second clip.
这个步骤还没有翻译 帮忙翻译一下
Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
Use tweezers or your fingers to disconnect the cable using its blue pull tab.
从前壳中的按钮上拆下三个硅胶按钮垫:
方向键的方形垫
动作键的圆形垫
主页键的小键盘
如果要卸下触摸板、共享和选项按钮的硅胶按钮板,请执行此步骤。否则,请继续使用标准按钮集。
将新更换的零件与原装零件进行比较——安装前,您可能需要转移剩余部件或去除新零件上的粘合衬垫。
要重新组装您的设备,请按照本指南的相反顺序进行操作。
将您的电子垃圾送到R2或e-Stewards认证的回收商处。
119等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
23条评论
I pulled out my touch pad along with the motherboard when it was still attached how can I put this back in
Pull out the ribbon the way the tutorial says and then you can place the touchpad back correctly. It needs to be put in from the inside of the controller, not the outside.
This guide could be enhanced by showing the L1/L2, R1/R2 button cluster in some photos. I needed to replace the silicone grommet underneath the buttons due to Sony's design flaw of having R2/L2 press on the silicone with a blade shaped extension.
What to do If after cleaning some buttons no longer work? I was very careful when disassembling and reassembling the remote.
