跳转到主内容
加入维修社区 - 创建账户
DualShock 3 Front Shell Cover Replacement
你所需要的
  1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: 步骤 1 中的图像 1,2 DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: 步骤 1 中的图像 2,2
    • Flip the controller over and locate the five 7.2mm Phillips #0 screws securing the rear cover to the front cover.
    询问修复机器人
    添加评论
  2. DualShock 3 Front Shell Cover Replacement: 步骤 2 中的图像 1,3 DualShock 3 Front Shell Cover Replacement: 步骤 2 中的图像 2,3 DualShock 3 Front Shell Cover Replacement: 步骤 2 中的图像 3,3
    • Using the Phillips #0 screwdriver, remove the five screws holding the rear/back cover in place.
    询问修复机器人
    添加评论
  3. DualShock 3 Front Shell Cover Replacement: 步骤 3 中的图像 1,2 DualShock 3 Front Shell Cover Replacement: 步骤 3 中的图像 2,2
    • Gently lift the rear cover away from the rest of the controller starting from the bottom side adjacent to the analog stick controllers.
    • Push gently by sliding the rear back forward towards the top edge of the dual shock controller to prevent tripping the two bottom triggers labelled (2).
    询问修复机器人
    添加评论
  4. DualShock 3 Front Shell Cover Replacement: 步骤 4 中的图像 1,1
    • Lift the rear cover off of the controller to expose the interior.
    询问修复机器人
    添加评论
  5. DualShock 3 Front Shell Cover Replacement: 步骤 5 中的图像 1,3 DualShock 3 Front Shell Cover Replacement: 步骤 5 中的图像 2,3 DualShock 3 Front Shell Cover Replacement: 步骤 5 中的图像 3,3
    • Carefully detach or disconnect the lithium polymer battery from the motherboard.
    • The wires are fragile, be careful not to break them when pulling out the battery as they can break easily.
    询问修复机器人
    添加评论
  6. DualShock 3 Front Shell Cover Replacement: 步骤 6 中的图像 1,3 DualShock 3 Front Shell Cover Replacement: 步骤 6 中的图像 2,3 DualShock 3 Front Shell Cover Replacement: 步骤 6 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove five 7.2 mm screws from the motherboard.
    • Lift the motherboard, vibration motors and analog module joysticks pads all in one connection, away from the shell.
    询问修复机器人
    添加评论
  7. DualShock 3 Front Shell Cover Replacement: 步骤 7 中的图像 1,2 DualShock 3 Front Shell Cover Replacement: 步骤 7 中的图像 2,2
    • Carefully lift the rubber or plastic part holding the button triggers labelled (2) in place.
    • Be careful not to strip the plastic rubber holding the triggers in place.
    • Slide the trigger button retainers away from the front shell. Set them aside.
    添加评论
  8. DualShock 3 Front Shell Cover Replacement: 步骤 8 中的图像 1,1
    • Set aside the colored buttons and lift the white rubber part holding the Dpad buttons in place to securely remove it.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
York University, Team 1-28, O'Regan Fall 2021 York University, Team 1-28, O'Regan Fall 2021 的会员
YORK-O'REGAN-F21S1G28
1 名成员
创作了3篇指南
1指南评论
The original 6 axis controller I got with my PS3 back in the day has different size screws than the gold plated one I got a few years later. They're about 3 mm longer too
Gregory Hedges - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 46
过去 30 天: 231
总计 7,909
